Results 1 to 10 of 17
    Default Adding To Cart Via Product Listing without going to the Product Info Page
    What could I do to make it so that when a customer clicks "add to card" via product listing it does not jump to the product info page. I would like it to say on the same page, just like every other site. Please check out this site Walmart...
    http://www.walmart.com/cp/Anime-Action/1010220
    Click on any item in the product listing and it adds the selected item to your cart without going to another page.
    I have been searching for a solution for days and have found nothing that works. At least not one that works in my version of Zen Cart. How can I achieve this?
    Thank you,
    Feb 2005
    Lansing, Michigan USA
    Default Re: Adding To Cart Via Product Listing without going to the Product Info Page
    Hard to say without seeing your site, but setting Admin - Configuration - Product Listing - Display Multiple Products Qty Box Status and Set Button Location to 0 does that for me.
    If your products have any attributes (even a single "download type" attribute), they cannot be added to cart without first going to the product info page to select the attribute(s). In most cases, this is a functional necessity, though a single download attribute has nothing to choose and is just an artifact of the system setup.
    My site is already set up like that, it does not really do what I am looking for. I put the link at the end of this post. Thanks,
    I don't have any attributes on any products but I understand what you are talking about. Thanks,
    Here is a link to my site.
    http://www.schobookcollectibles.com/...x&cPath=67_148
    Click on "Add to Cart" on one of the items and it brings you to the item info page. I want it to stay on the same page so a customer can easily continue shopping without losing their place or having to hit the back button all the time.
    There was a code change in a recent version to make the return go to the original page rather than the product info page... perhaps that was in v1.5.1?
    Change the setting stevesh mentioned to 1, 2 or 3 to make the "add" function happen after all qty selections have been made and a button at top/bottom of page is clicked.
    I would rather not upgrade since it can cause serious problems with some of the mods I have installed.
    I found this here
    http://www.zen-cart.com/showthread.p...duct-info-page
    but it does not work, since I have 1.5. Do you know where I can find a code that I can manually put it to make it happen?
    Do you know it doesn't work, or are you assuming it won't work? Have you tried it on a testing copy of your site?
    It probably would have been better to continue the discussion on the other thread, where solutions have been posted, instead of starting all over again.
  1. v154 Product listing page "add to cart" button redirects to product info
    By Mikey D in forum General Questions
    Last Post: 9 Mar 2018, 03:41 AM
  2. Adding a link to product page into the admin's product listing.
    By thebigkick in forum Customization from the Admin
    Last Post: 16 May 2012, 07:02 PM
  3. Adding additional Product Details to the Product Info Page??
    By Adrian88 in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Jan 2009, 09:38 AM
  4. Adding the Shopping Cart Contents Directly On The Product Listing Page
    By watzursn in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Sep 2008, 12:18 AM
  5. Adding columns in addition to product image and name in the product listing page
    By thunderbird2004 in forum Setting Up Categories, Products, Attributes
    Last Post: 22 Mar 2008, 10:41 PM
