Results 1 to 3 of 3
    Feb 2012
    Default Side box/ top menu box has dissapeared...
    Hi there, I think I am in the right place!
    I have been using my zencart site successfully for a while with the theme of my choice which had a search bar at the top of my web page as well as down the side.
    I haven't changed any code, however I went into the sidebox menu on the admin and changed a few side boxes around to change the layout a bit. I then pressed to reset to their original and move them around from there. I decided it was better how it was so have changed all the boxes on that page back to where they were.
    The problem is that now there is no search box at the top and I cannot get it back. Does anyone have any ideas? If you need to take a look the website is craftjam.co.uk
    Amy
    Default Re: Side box/ top menu box has dissapeared...
    What do you have set for "search_header.php"
    Feb 2012
    Hahaha, turning it off and on seemed to fix it!
    A
  1. v150 More information side box has disappeared
    By apt763 in forum Basic Configuration
    Last Post: 11 Jun 2012, 02:28 PM
  2. Top align center column with top, left side box?
    By kirkbross in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Jan 2010, 07:36 AM
  3. Top sales side box
    By andrewmax81 in forum General Questions
    Last Post: 12 Dec 2009, 04:03 PM
  4. Bringing icons to top of side box
    By mooncavecrystals in forum General Questions
    Last Post: 13 Dec 2007, 12:46 AM
