Results 1 to 3 of 3
    Dec 2012
    Default Checkout Errors with Products with Attributes and Tax Cloud plugin
    I am running a new install of v1.5.0, PHP Version: 5.3.18, MySQL v. 5.0.77, with the Andover Modern template on a dev site. I have installed Tax Cloud v1.5.
    I did not try to checkout until I added Tax Cloud. When I checkout with a product in my cart that does NOT have attributes I can complete the checkout process. When a product HAS attributes I can look at my cart, choose to checkout, log into my account (if I'm not already logged in) and then I receive "WARNING: An Error occurred, please refreshå the page and try again."
    When I look at the error log it says:
    "[17-Jan-2013 12:46:22 America/New_York] PHP Fatal error: 1054:Unknown column 'poval.products_options_values_name' in 'field list' :: select popt.products_options_name, poval.products_options_values_name,
    pa.options_values_price, pa.price_prefix
    from products_options popt,
    products_options_values poval,
    products_attributes pa
    where pa.products_id = '840'
    and pa.options_id = '52'
    and pa.options_id = popt.products_options_id
    and pa.options_values_id = '126'
    and pa.options_values_id = poval.products_options_values_id
    and popt.language_id = '1'
    and poval.language_id = '1' in /home/tszen/www/includes/classes/db/mysql/query_factory.php on line 101"
    Additionally, when I try to look at a product's attributes in the Attribute Controller this message shows up under the Legend and I cannot view the actual attribute:
    "WARNING: An Error occurred, please refresh the page and try again.
    1 |"
    Any help in pointing me in the correct direction to solving this error will be appreciated. Thanks.
    Dec 2012
    Default Re: Checkout Errors with Tax Cloud plugin
    I see that for some reason the title does not correctly reflect my problem. I would swear I never wrote that title - I had written "Checkout Errors with Products with Attributes." I only discovered this a day after posting and apparently it is too late to edit or even delete this post and repost under the correct title. If a monitor reads this can you please change the title for me? Thanks.
    Default Re: Checkout Errors with Products with Attributes and Tax Cloud plugin
    Post title changed.
    How certain are you that this isn't related to Tax Cloud? Why so?
    The error message literally means that your products_options_values table is missing the products_options_values_name field. And that field is present in every version of Zen Cart released in the last 8 years ... unless you've changed it either by deleting it yourself or using some mod that has significantly altered the database.
  1. v150 Has Any merged Tax Cloud and Fast and Easy Checkout
    By joem83 in forum All Other Contributions/Addons
    Last Post: 7 May 2015, 12:52 AM
  2. v139h Having problems with v1.3.9h and Tax Cloud 1.3.9
    By Kamino84 in forum All Other Contributions/Addons
    Last Post: 15 May 2013, 07:58 PM
  3. Replies: 1
    Last Post: 21 Jul 2009, 10:40 PM
  4. how to setup product with 19% tax and attribute with 6% TAX
    By manage-it in forum Setting Up Categories, Products, Attributes
    Last Post: 22 Jul 2008, 10:25 PM
  5. Blank page errors with login checkout and add to cart
    By Dreamwater in forum General Questions
    Last Post: 27 May 2008, 01:14 AM
