Results 1 to 10 of 11
    Jun 2011
    Default Need help urgently - can't figure out how something was done in the past
    At some point in the past I made a change based on a thread on the forum. This change made the cart disable the add to cart button and display out of stock when inventory was less than X amount. I have absolutely no idea where I did this and I'm having no luck finding the thread. Any help on how to reverse this would be GREATLY appreciated.
    Owner - MatchLock Arms, LLC and M&M Toys (Yes I sell toys and guns, but not toy guns)
    http://www.matchlockarms.com
    http://www.mandmtoys.com
    Default Re: Need help urgently - can't figure out how something was done in the past
    stock should be settings in
    admin > config > stock
    Jun 2011
    Kobra,
    Thanks for the reply, I could be wrong so please forgive me if I am but I'm 99% sure this was done on the code level. Something is telling zen cart that if inventory is less than 4 show out of stock.
    Take a look at this for an example https://www.matchlockarms.com/shotgu...4-rs-rfl-combo
    if this is fixable in the admin I just don't see it.
    Thanks again for your reply!
    Since you can not recall...your best bet is to download your files and grab a fresh distribution of the version you are using and run a file compare....
    Prior to this can you switch to the classic template and see if the issue persists
    If not then you only need look to your template override files
    Might be in this section of includes/classes/order.php
              if ($stock_left <= 0) {
                // only set status to off when not displaying sold out
                if (SHOW_PRODUCTS_SOLD_OUT == '0') {
                  $db->Execute("update " . TABLE_PRODUCTS . " set products_status = 0 where products_id = '" . zen_get_prid($this->products[$i]['id']) . "'");
    Jun 2011
    I just got super excited when i saw your post and thought this was it for sure. Unfortunately it was not. I have a dev store (dev(dot)matchlockarms.com) setup that doesn't have this issues/change made to it and i did a diff on the files. They match exactly so the change wasn't made here. This has to be something very simple it's just buried somewhere. anyone know how to do a diff in linux that would compare all the files between the dev site and the production site? Thank you all for your help btw.
    Jun 2011
    I just used your suggestion of switching to classic and the change was made somewhere which causes it to exist in that template as well. Would this be a DB change perhaps? I can't believe i would change a core file and not use an override (BUT that's not to say i wasn't tired and did so :))
    Jun 2005
    Cumbria, UK
    It's most likely a MODULE, CLASS or a FUNCTION file.
    Unlikely to be a database issue - unless the value that determines the behaviour is adjustable somewhere in admin (but this would have been part of the code change as well.
    20 years a Zencart User
    Jun 2011
    Quote Originally Posted by schoolboy View Post
    I'm familiar with the location of the modules and the functions, but where are the CLASS? Thanks!
    Jun 2011
    Quote Originally Posted by matchlock View Post
    Disregard! You let this horse to water and I was able to drink and find exactly where this was done! Schoolboy, thank you so much! Also thank you to the others who contributed as well.
    for reference:
    in includes/functions file functions_general.php
    Original line
    case ($button_check->fields['products_quantity'] <= 0 and SHOW_PRODUCTS_SOLD_OUT_IMAGE == '1'):
    My line
    case ($button_check->fields['products_quantity'] <= 3 and SHOW_PRODUCTS_SOLD_OUT_IMAGE == '1'):\
    note the greater than equal to 3
    For anyone wonder or needing this function and finding this thread in the future here is the back story.
    My site is fed inventory counts from multiple wholesalers. Because of this fact if the inventory is low at a wholesaler I may not be able to secure an item before they sell out therefore leaving my customer without the product they ordered. The setting above solves this problem (sort of). What the setting does is sets a product to out of stock if the quantity is less than 3 available. This is great as a blanket setting, but occasionally i have inventory on hand (which is the case now). It would be nice and I'm sure it is possible (not a php guru) to exclude certain products from the setting but should you need to do something similar this is how it is done.
    All the best,
  1. v150 Help Can't Figure out how to move header search box!!
    By Darion in forum General Questions
    Last Post: 15 Sep 2012, 07:17 PM
  2. Replies: 0
    Last Post: 20 Jun 2009, 11:25 AM
  3. Something I can't figure out.
    By holley2346 in forum General Questions
    Last Post: 5 Feb 2009, 09:35 PM
  4. Can someone help me figure out how to do this...
    By MCanes in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Sep 2007, 05:54 AM
  5. I can't figure out how to use the newsletter manager!
    By awatts65 in forum General Questions
    Last Post: 9 Jul 2006, 10:53 AM
