Results 1 to 5 of 5
    Feb 2013
    New York, New York, United States
    Default Meta Tags display META_TAG_TITLE.. Need help!!
    I must of screwed up a file while customizing my site. I can not get any meta tags to work. My site shows META_TAG_TITLE for its title and the same goes for description and keywords. Does anybody know how to fix this? Thank you in advance.
    Default Re: Meta Tags display META_TAG_TITLE.. Need help!!
    Showing a constant usually is the result of a mis edited file and normally the omission of one or both of the single quotes around the value
    Chances are you've busted your /includes/modules/YOUR_TEMPLATE_NAME/meta_tags.php or /includes/modules/meta_tags.php.
    Put back the original version of that file.
    Feb 2013
    I check the files you mentioned and the /includes/modules/meta_tags.php is there and appears to be fine. The /includes/modules/YOUR_TEMPLATE_NAME/meta_tags.php file is not there. Do i drop it straight into that folder?
    No. That would be an override folder, and if you're not altering the file, then no override is needed.
    Articles on overrides: http://www.zen-cart.com/search.php?d...uery=overrides
    Another thing that could cause META_TAG_TITLE to show up instead of the actual title content would be if your template has been busted by hacking things out of it. What's different about your template's html_header.php file vs the original one that comes with Zen Cart ... and why?
  1. Need Help with meta tags
    By weartmc in forum Templates, Stylesheets, Page Layout
    Last Post: 7 Jul 2008, 02:39 PM
  2. Meta tags problem, need help, please...
    By Kruna in forum General Questions
    Last Post: 22 Jun 2007, 11:18 PM
