Yes it will ...
I am trying to fool with this in my spare time ... however, that is very limited right now ...
Yes it will ...
Hi Ajeh
Thanks for fooling with it in your spare time. Thanks again Scott
Hi Ajeh
Any luck with this. What should I do to fix it? Thanks again. Scott
This is approximately what Catalog files are missing for this new Product Type for Gold ...
You might need to tidy things up, but it should give you a good start ...
Hi Ajeh
Thank You. Do you no why it take 30 seconds or more to navigate between pages on my site? Godaddy says its Zencart. Here is the site again. www.buyingsilverdollars.com/zencart Thanks again Scott
If you look in your Zen Cart Admin at the Tools ... Server Info ... what do you see in the top from the menubar down to where it says the PHP Version?
Also, can you turn on your Parse Times in the Configuration ... Logging ...
Display The Page Parse Time
Display the page parse time on the bottom of each page
You do not need to store the times to display them in the Catalog
true
false
Here is what it says:
Server Information
Server Host: p3nlhg633.shr.prod.phx3.secureserver.net (184.168.152.207) Database Host: zcbsd71487.db.8249646.hostedresource.com (50.63.226.127)
Server OS: Linux 2.6.32-279.19.1.el6.x86_64 Database: MySQL 5.0.96-log
Server Date: 03/19/2013 18:49:52 Database Date: 03/19/2013 18:49:52
Server Up Time: 18:49:52 up 32 days, 7:11, 0 users, load average: 19.54, 28.50, 41.72 HTTP Server: Apache
PHP Version: 5.2.17 (Zend: 2.2.0) PHP Memory Limit: 64M PHP Safe Mode: Off
PHP File Uploads: On Max Size: 32M POST Max Size: 33M
Database Data Size: 584 kB Database Index Size: 501 kB
Zen Cart
Zen Cart 1.3.9h
Database Patch Level: 1.3.9h
v1.3.9h [2011-09-05 16:57:18] (Fresh Installation)
Contact your hosting provider and tell them your server is showing:
Indicating that the load on your server is ridiculously high and either there is a problem on that server or you need to be moved to a different server without so many domains on them or better set up ...
Hi I called up GoDaddy and they said there server is OK. They have a virtual private server available they said that ranges in price from $30 per month to $150 per month. You think I should go with that? Thanks again Scott
