Results 1 to 3 of 3
    Aug 2008
    Default Issue with UPS XML Auto Export
    I am using Zen Cart 1.5
    I just installed superorders which worked fine.
    But then I installed this module so that I can export items to UPS and nothing works. It says that once I upload the files I should see a new link under Tools but I don't . any ideas if this works with Zen cart 1.5?
    http://www.zen-cart.com/downloads.php?do=file&id=505
    Default Re: Issue with UPS XML Auto Export
    It was designed for v1.3.7, so it definitely wouldn't have any admin-menu support in v1.5.0 or newer.
    I just added the admin menu support for v1.5.0 and updated with a new zip. I HAVE NOT TESTED ANY OF IT ... I simply added a file to handle the admin menu piece, and updated the Readme with a note about which files to install or avoid based on your ZC version.
    I make no assertion as to whether the rest of the plugin will work with contemporary versions of Zen Cart or with UPS Worldship.
    Others might appreciate if you post back to indicate whether it works satisfactorily for you.
    Aug 2008
    Bingo, thanks
  1. Need Help with UPS XML Auto Import
    By Craig MD in forum Addon Shipping Modules
    Last Post: 18 Jan 2010, 07:44 PM
  2. UPS XML Auto Export
    By erezw in forum All Other Contributions/Addons
    Last Post: 2 Oct 2009, 05:35 PM
  3. UPS XML Auto Export is missing Top Level Element
    By engine411 in forum Addon Shipping Modules
    Last Post: 25 Jun 2009, 04:58 AM
  4. UPS XML Auto Export & Worldship -- too costly
    By Twbeebe in forum Built-in Shipping and Payment Modules
    Last Post: 30 Sep 2008, 06:50 AM
  5. UPS XML Auto Export
    By cryogenicz in forum All Other Contributions/Addons
    Last Post: 24 Sep 2008, 11:22 AM
