thanks for all your response and being patient with me. However, that FAQ says "Zone Definitions can be created by adding 1 by 1 each Zone or SQL" then proceeds to explain how to add just the 2 extra states to make it all 50 states, then goes into sql stuff. Im still wondering how I go about properly creating the zone definitions with the first option being edit the zone name and give it a description which creates a folder. you can then click into that folder and insert a "new sub zone" which lets you select the country, which in my case is the usa, then the zone, which I have the option of selecting a state withing the usa. now, heres were im stuck, It lets you insert as many zones as you want into the folder. so if I want a separate flat shipping rate for each state, should I create 50 folders, giving each folder a state name, then inserting that state into it, or should i create one folder, and then INSERT all 50 state zones into it, which would be 50 zones in one folder....
... or, get the Zone Table add on from the plugins and build your 50 Zone Definitions ...
