    Feb 2013
    Default No shopping cart after adding products.
    I'm a new user of Zen cart; installed V1.5.1 but I cannot get to display cart after adding products.
    I set "True" in the Admin/mystore/Display Cart After Adding Product.
    I can see the empty cart at sidebox and it open cart page.
    There is no cart display when I click on a product in the main page.
    I'm stuck. Could someone help?
    Feb 2005
    Lansing, Michigan USA
    Default Re: No shopping cart after adding products.
    A link to the site so we can see exactly what happens when you add a product would help.
    N of San Antonio TX
    A common cause for this is a custom template that has hard-coded the feature so it doesn't display. That's why we need to see a site to tell.
    A little help with colors.
    Feb 2013
    here you go harmonieliving.com
    appreciate your help.
    Feb 2005
    It's not a template problem, as you're using the classic template. Don't do that. Create your custom template before you go any further.
    We can't add products to your cart and help with your issue, as you have your store set to showcase mode.
    Feb 2013
    I can move forward now; thank you for the tip to a new zenner.
  1. Display Shopping Cart After Adding Product
    By Semenek in forum General Questions
    Last Post: 12 Sep 2010, 04:09 AM
  2. Blank page after adding item to shopping cart
    By jcountryman in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Feb 2010, 04:09 PM
  3. Blank page after adding item to shopping cart
    Last Post: 17 Jun 2009, 06:41 PM
  4. Jump to Shopping Cart after adding product
    By rectangle in forum Basic Configuration
    Last Post: 15 Jun 2009, 03:33 AM
  5. Shopping Cart wont display after adding product to cart
    By fmf_tactical in forum General Questions
    Last Post: 6 Mar 2009, 03:43 AM
