    Sep 2008
    Default How does barcode scanning with numinix for inventory crontrol work?
    I have tried to look for this topic on internet, but i didnt find any practical "step by step" on how this actually works.
    I have a shop and we have around 500 products. The most challenging situation is to have control over the inventory. For now when we receive goods from supplier, we update the quantity (put the number of items) manually in zen cart for that product. So if i have 50 of product A, then we update the product with 50. This is a hard way to do i think. A normal shop have a barcode scanner.
    I also have barcode scanner but i have never used it, since i dont know how.
    Now, we have a physical store also in addition to our webside and customers also buy here directly in the store. Then later we have to go to admin and reduce the qty.
    In some situation we also have to send a replacement to the customer. So if we forget to update the qty in admin, then this could result in wrong qty at stock.
    I have read about numinix. Can this be the solution on how to keep better and accurate inventory control?
    To keep the questions under control, i have it in numbers.
    Questions:
    1. Do i have to put a barcode sticker to all products in stock and scan each product? If so, how does the qty of product A being updated on zen cart in admin?
    2. Where and how is the barcodes made? In excel?
    3. Do i have to download the qty of products from the zen cart database, import it to excel, open the file, produce a barcode for each product, print that out and label each product with that barcode and scan?
    If not, how so?
    4. The barcode scanner we have is Cipher lab 1090+. Can that be used for this purpose?
    Can someone please help? The way we do it today is very time consuming, and i am sure a lot of others would be thankful for this. Would appreciate it.
    Default Re: How does barcode scanning with numinix for inventory crontrol work?
    What module are you referring to??
    Yes if they do not have a barcode when received as to the how....what module are you referring to?
    There are barcode printers available
    If not, how so?
    Again without knowing the feature of the module, I can not respond
    Sep 2008
    Thanks for your answer. I think this is the module:
    https://www.numinix.com/downloads/ze...arcodes-dl-772
    Sep 2008
    Ok. I will try this later.
    But can you tell me in short steps how this works? I install the software, download the csv file for quantites in my zen cart database, i make the barcodes, scan the product and upload the csv file back?
    Usually your scanner will have settings that can be set to store scanned items either incoming or outgoing (sold)
    Also it should have a port to interface with your computer and some application
    Where you can create a csv or copy and paste into easy populate and upload to your store
  1. v151 inventory barcode Android apps
    By unckle fester in forum General Questions
    Last Post: 9 Apr 2014, 10:46 PM
  2. v139h Anyone know how to make Easy Populate work with Numinix Product Fields?
    By scottm4321 in forum All Other Contributions/Addons
    Last Post: 25 Apr 2013, 01:01 PM
  3. NUMINIX Barcode Add On
    By Nick1973 in forum All Other Contributions/Addons
    Last Post: 7 Jul 2011, 04:42 PM
  4. Inventory Deplete - How Does It Work?
    By audrianna21 in forum General Questions
    Last Post: 9 Feb 2011, 05:20 AM
  5. How does Call For Price work?
    By LilleyPadGifts in forum Setting Up Categories, Products, Attributes
    Last Post: 28 Dec 2008, 03:16 AM
