    Mar 2011
    Default Subdomain for testing setting issue
    I have a site all up and running but needed a test Zencart where I can play with so mistakes will not matter as i am new so there will be a lot ! , so I installed it under a subdomain (domain not active just a dummy so i will be using my IP) it all installs and i can access it fine but i get no Images ? The admin has images ?
    Spoke to my Provider who said i need to change some setting in my Configuration , but he could not tell me what !
    Settings
    I can access my site using my IP example below
    http://00.00.00.00/~mydomain/demosite.co.uk/
    Configuration.php... where am i going wrong ?
      define('HTTP_SERVER', 'http://00.00.00.00');
      define('HTTPS_SERVER', 'https://00.00.00.00');
      define('DIR_WS_CATALOG', '/~mydomain/demosite.co.uk/');
      define('DIR_WS_HTTPS_CATALOG', '/~mydomain/demosite.co.uk/');
    Hope this makes sense
    Australia
    Default Re: Subdomain for testing setting issue
    Quote Originally Posted by psvialli View Post
    Please provide a copy of the next two lines in your configure.php file. (Specifically, we need to know what you have set for
    define('DIR_WS_IMAGES'. '') ;
    tip: It should probably be
    define('DIR_WS_IMAGES'. 'images/') ;
    Rod
    Mar 2011
    Yes i left those as is
    Jun 2005
    Cumbria, UK
    You've done this in a rather "clunky" way.
    I find that the EASIEST way is to create a new sub-folder in the public_html root. Call it " testing " or whatever...
    Then, create a CLONE of your live website (Copied database with a DIFFERENT name, and copied files - which are housed in testing.)
    configure.php for LIVE SITE looks like this:
      define('HTTP_SERVER', 'http://your-website.com');
      define('HTTPS_SERVER', 'https://your-website.com');
      define('DIR_WS_PHPBB', '/');
      define('DIR_FS_CATALOG', '/home/youraccount/public_html/');
      define('DB_TYPE', 'mysql');
      define('DB_PREFIX', '');
      define('DB_CHARSET', 'latin1');
      define('DB_SERVER_USERNAME', 'youraccount_yourusername');
      define('DB_SERVER_PASSWORD', 'YoURPassWoRd');
      define('DB_DATABASE', 'youraccount_livedatabase');
      // For SQL_CACHE_METHOD, you can select from:  none, database, or file
      // ie: /path/to/your/webspace/public_html/zen/cache   -- leave no trailing slash
      define('DIR_FS_SQL_CACHE', '/home/youraccount/public_html/cache');
    // EOF
    configure.php for TESTING SITE looks like this:
      define('DIR_WS_CATALOG', '/testing/');
      define('DIR_WS_HTTPS_CATALOG', '/testing/');
      define('DIR_FS_CATALOG', '/home/youraccount/public_html/testing/');
      define('DB_DATABASE', 'youraccount_testingdatabase');
      define('DIR_FS_SQL_CACHE', '/home/youraccount/public_html/testing/cache');
    // EOF
    20 years a Zencart User
    Jun 2005
    Cumbria, UK
    I then use a htpasswd (configured in C-Panel) to restrict access to testing folder.
    I also alter html_header.php to force noindex,nofollow
    I ALSO CHANGE THE MAIN LOGO to alert me that this is the TESTING SITE AND NOT THE LIVE SITE! (As they would otherwise look identical, you could get confused about which one you are working on.) I sometimes make the background RED IN COLOUR:
    body {
    	margin: 0;
    	font-family: verdana, arial, helvetica, sans-serif;
    	font-size: 62.5%;
    	color: #000000;
    	background-color: #ff0000;
    Mar 2011
    thanks worked a treat !
  1. Setting up a subdomain or Not?
    By bearlymakinit in forum General Questions
    Last Post: 12 Jun 2011, 11:44 PM
  2. Setting up a testing server
    By KADesign in forum General Questions
    Last Post: 10 May 2010, 06:40 PM
  3. Setting up a subdomain
    By philip56 in forum Installing on a Linux/Unix Server
    Last Post: 22 Jan 2010, 12:18 PM
  4. Setting up ZC on a Local Testing Server
    By boukmn in forum Installing on a Windows Server
    Last Post: 29 Aug 2008, 10:26 PM
  5. setting up a testing site
    By Minnie Mouse in forum General Questions
    Last Post: 18 Apr 2007, 01:07 AM
