Results 1 to 5 of 5
    Dec 2007
    red flag Help needed - strange problem occured when changed server
    Hi Guys,
    I just moved old version zencart to a new hostgator VPS server. Everything works fine except my site can not be seen on any windows XP machine. CRAZY I KNOW
    I get this error:
    The webpage at ------ might be temporarily
    down or it may have moved permanently to a new web address.
    Error 108 (net::ERR_ADDRESS_INVALID): Unknown error
    All other operating systems are fine. Crazy right
    Before being asked, yes i am planning to upgrade to the latest version. But that is months away with many many hours of work ahead to complete it. I need a quick fix i can pass on to my host in the meantime.
    And no it is not a template issue as everything worked fine when i was on a shared server XP included.
    And yes i have contacted the host several times, with no luck as they could really care less if you have a problem outside of thier limited server knowledge.
    Yes i have googled this problem for no luck at all.
    Yes i know it is a dead OS but guess what my users are old fashioned and will stick with it till there PC cases rust and fall apart. I am getting complaints daily.
    I am wondering if anybody has ever had this XP problem??? or even heard of it happening???
    Did anyone ever find out how to fix it??? It sure leaves a bad taste in my mouth
    Dr Byte you might be the only one who can help me on this crazy problem.
    HELP PLEASE LOST ZENCARTER IN NEED OF A XP FIX
    I love Zencart!
    Default Re: Help needed - strange problem occured when changed server
    What is your site url?
    Dec 2007
    red flag Re: Help needed - strange problem occured when changed server
    Sorry thought it was in my signature:
    http://www.primecutsbodybuildingdvds.com
    I love Zencart!
    Well on XP as you know the site does not load
    Checking at
    http://www.internic.net/whois.html
    This is what is listed as your nameservers
    Name Server: NS1.VIDEO-OF-BODYBUILDING.COM
    Name Server: NS2.VIDEO-OF-BODYBUILDING.COM
    If these are not what your nameservers should be you need to correct this
    Otherwise I would expect that being a VPS - that your server configuration is not correct
    Feb 2012
    mostly harmless
    Most often I have seen this message when network connectivity issues exist between the computer and the server.
    This can be a wide range of things including (but not limited to): misconfigurations of proxies, misconfiguration of network software/hardware and/or routing, interfering firewalls, overloaded servers or internet connections, misconfigured server settings or software, corrupted temporary internet files (including cookies), and malware on the client.
    May not be related (or may be).
    I'm seeing a number of things including your site taking between 3-5 seconds to respond to the initial request for data (you can use FireBug or an external site such as webpagetest.org for more detailed speed loads). This seems a little excessive...
  1. changed server, now getting strange characters near £ signs
    By barricades in forum General Questions
    Last Post: 9 Oct 2013, 10:35 PM
  2. strange styling problem - help needed
    By toodamnbroke in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Nov 2011, 04:20 PM
  3. URGENT Help needed! Internal Server Error problem...
    By nas111 in forum General Questions
    Last Post: 22 Dec 2009, 03:45 PM
  4. When I changed my server, Payment module not
    By kevinm2 in forum Basic Configuration
    Last Post: 7 Jul 2006, 12:25 AM
  5. Strange problem when I changed hosts.
    By Reesy in forum General Questions
    Last Post: 28 Jun 2006, 04:37 AM
