I've been searching for solutions to my problem but couldn't find a way to implement what I'm trying to do or any detailed documentation about the zen cart 'multiple_products_cart_quantity / multiple_products_add_product' functions.
Basically what I'm currently doing is having a single product order page built with Javascript (to live calculate totals, validation etc) with a bunch of products and a quantity field per product to quickly build an order and then with a single click the order gets added to the cart (modified the cart slightly so the cart gets cleared, then populated, then skipped to the shipping page).
This works great, however I now have a problem that I need to include products with a single attribute (size) and I can't figure out how to format my form to make this work.
The form basically works like this:
<form name="multiple_products_cart_quantity" action="index.php?main_page=index&cPath=65&sort=20a&action=multiple_ products_add_product" method="post" enctype="multipart/form-data">
<input type="hidden" name="securityToken" value="<?php echo $_SESSION['securityToken']; ?>" />
Product 1
<INPUT TYPE="Text" NAME="products_id[101]" VALUE="0">
Product 2
<INPUT TYPE="Text" NAME="products_id[102]" VALUE="0">
Product 3 with attributes
<select name="id[2]" id="attrib-2">
<option value="68" selected="selected">1 lbs (~2 quarts)</option>
<option value="69">5 lbs (~10 quarts) ( +$75.00 )</option>
<option value="70">10 lbs (~20 quarts) ( +$154.00 )</option>
<option value="71">30 lbs (~60 quarts) ( +$444.00 )</option>
<option value="72">50 lbs (~100 quarts) ( +$604.00 )</option>
</select>
<INPUT TYPE="Text" NAME="products_id[103]" VALUE="0">
Product 4
<INPUT TYPE="Text" NAME="products_id[104]" VALUE="0">
<input type="Submit" value="Proceed to checkout">
</form>
I've tried doing things like naming id[203:2], product_id[203:22e62e63fb8f092da731e8f12ebd81a9] (the key assigned when I add the product with value 69 to the cart from the individual product page - not sure where this originates - I presume from the attributes assigned).
So far all I get is either product 3 doesn't show up at all or it shows up with the default attribute (not the one I chose).
Anybody have any idea how I can accomplish this? I'm basically wanting to be able to add a mix of regular products and products with attributes in one step to the cart.
