Results 1 to 2 of 2
    Mar 2010
    Default Question about 'Featured Products for month'
    I added the products that I had just added to be displayed in the 'Featured for May'. I deleted all the products in the featured products and then added the new products. But the old items are still showing up as well as the new items. Where else do I look for the older items so they won't show up with the new items?
    Sep 2005
    Waikato, New Zealand
    Default Re: Question about 'Featured Products for month'
    Can you give a link to where this is happening,
    1) What do you see when you go to
    admin --> Catalog --> Featured products
    Are the deleted products showing there?
    Are all of the ones you actually want showing there?
    If you disable one by clicking on the green square icon under status, does it disappear from the front end of the store?
    If the ones you don't want are showing there, what happens if you click on the green square, do they disappear from the front end?
    2) they should drop out if it is truly the featured products section
    this sounds more like someone has renamed the "New products for" section heading to "Featured products for" via the english.php file
    What link is showing where you are viewing the "Featured Products for May"
    Is it this
    YOURSITE/index.php?main_page=featured_products
    If not what happens if you append that to your site root?
    3) This is a bit out of left field but what happens if you go to
    Admin --> Configuration --> New Product Listing - Limited to ...
    and set it to 7
    Does that make a difference??
    I only ask as I have seen a site where they renamed the New Products section to Feature Products so it would show nicely on the front page and on the category pages
    Webzings Design
    Semi retired from Web Design
  1. v151 How to change Featured Products for the "Month Of X" to Weekly
    By HTDigitals in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Aug 2013, 08:17 PM
  2. I want to enable the "New Products for [insert month]"/Featured for subpages
    By JE2009 in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Jul 2009, 04:05 PM
  3. Changing New Products for 'Month' to Featured Product.
    By PuckQ in forum General Questions
    Last Post: 16 May 2009, 05:07 PM
  4. how do I change "New Products for 'month' and 'monthly specials for 'month'
    By Fatum in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Mar 2008, 07:08 PM
  5. Question about Special Products and Featured Products Display
    By kaleidoscopecards in forum Setting Up Categories, Products, Attributes
    Last Post: 17 Feb 2007, 06:19 PM
