NOTE: Mod, please don't move this to the EP4 support page! I don't think it has anything to do with EP4. I was able to duplicate the problem by manually dropping code into new products. Same thing happened, with or without EP4.
Hi!
I recently uploaded about 1000 products using EasyPopulate 4.0 and hundreds of the products showed up with 'markup' types of weird characters.
To figure out what was going on, I picked a product, navigated to it in Admin, then clicked on SOURCE VIEW. Unable to find anything queer, I hit PREVIEW, then UPDATE. Low and behold, it fixed itself!
I repeated this several times, each time fixing all problems on every product I tried.
Here is an example of a PROBLEM:
Use ESD Shielding bags to follow ANSI/ESD S20.20 fundamental ESD control principle: “Transportation of ESDS items outside an Electrostatic Protected Area requires enclosure in static protective materials; low charging and static discharge shielding materials are recommended.”
This is what it looks like after I UPDATE:
Use ESD Shielding bags to follow ANSI/ESD S20.20 fundamental ESD control principle: Transportation of ESDS items outside an Electrostatic Protected Area requires enclosure in static protective materials; low charging and static discharge shielding materials are recommended.
MY QUESTION:
Is there a way to automate the UPDATE process with an SQL command I can just drop in the SQL Query Executor?
It would take me all day to go thru Admin, click on each product and hit Preview, then Update.
Any help would be greatly appreciated!
~Mike
