Looking at this guide, it seems that you just need to add some meta tags to your header (or footer, maybe).
Typically, these files are located at /includes/templates/<your_template>/common/html_header.php
If you open that, you should see something similar to this:
* @version $Id: html_header.php 19537 2011-09-20 17:14:44Z drbyte $
* load the module for generating page meta-tags
require(DIR_WS_MODULES . zen_get_module_directory('meta_tags.php'));
* output main page HEAD tag and related headers/meta-tags, etc
Put your meta tag where all the other meta tags are.
