Hello, I have been trying to do this for MONTHS! Basically it is suppossed to BE SUPER EASY, just moving the parts of code between <!--bof ZZZZZZZZZ Module --> and <!--eof ZZZZZZZZZ Module -->
and in fact it is, I just have to move them in the order I want them to show, the hard part is to get what I really want! Because every single small goobling (piece of code) looks to have its own mind! they do extrange things but never what I want to.
for example, the main image looks to have some sort of alignement because it goes always at the left side no matter what you change or where I move the code. and when, for example i placed the aditional images under the main image code, i get some images at the right sde of this image and then some other under this image, looks like this image is located into a cel or something making even harder to find a way to fix this, in other words, anything under the main image has toi have a size no bigger than the image because if its larger it will go under the image and not in the right side as desired, ths is something imposible to do because there are products with 2 images and some others with 20.
then, the attributres controller tends to give more spaces to the atriburtes or even put the last atribute under the "add to cart button" when I put that part of the code above the add to cart button code.
and when I put the add to cart button code at the end, it shows ON the "featured products banner" cutting that banner.
I have tried
<DIV style="float:right"> </DIV>
too but i get other undesired effects like moving all the aditional pitures to the right and making a complete mess where the add to cart button appears like an additional pitures and where spaces between atributes are uneven, this is a mess.
At the end, all asnwers are the same, just move the codes, but this is not working, I really realllly need help
What do I need to change or/and to add in order to get this: (attchd image)
Is there any need to change the main images file? (tpl_modules_main_product_image)
Do I need to use align, float,   "clearBoth or any other thing? (I have tried all this looking fort a solution in google but it is ovious that i will not go anywhere without knowing what do i need to do exactly.
Just in case: you can check the online store at www.SnSbikinis.com
Thank you!! :)
PS.- Just in case
here is the code of the actual tpl_product_info_display.php file
* Page Template
* @package templateSystem
* @version $Id: tpl_product_info_display.php 19690 2011-10-04 16:41:45Z drbyte $
<div class="centerColumn" id="productGeneral">
<!--bof Form start-->
<?php echo zen_draw_form('cart_quantity', zen_href_link(zen_get_info_page($_GET['products_id']), zen_get_all_get_params(array('action')) . 'action=add_product', $request_type), 'post', 'enctype="multipart/form-data"') . "\n"; ?>
<!--eof Form start-->
<?php if ($messageStack->size('product_info') > 0) echo $messageStack->output('product_info'); ?>
<!--bof Category Icon -->
<?php if ($module_show_categories != 0) {?>
* display the category icons
require($template->get_template_dir('/tpl_modules_category_icon_display.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_modules_category_icon_display.php'); ?>
<?php } ?>
<!--eof Category Icon -->
<?php if (PRODUCT_INFO_PREVIOUS_NEXT == 1 or PRODUCT_INFO_PREVIOUS_NEXT == 3) { ?>
* display the product previous/next helper
require($template->get_template_dir('/tpl_products_next_previous.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_products_next_previous.php'); ?>
<?php } ?>
if (zen_not_null($products_image)) {
<!--eof Main Product Image-->
<!--bof Product Name-->
<!--eof Product Name-->
// base price
$one_time = '<span >' . TEXT_ONETIME_CHARGE_SYMBOL . TEXT_ONETIME_CHARGE_DESCRIPTION . '</span><br />';
$one_time = '';
?></h2>
<!--bof free ship icon -->
<?php if(zen_get_product_is_always_free_shipping($products_id_current) && $flag_show_product_info_free_shipping) { ?>
<div id="freeShippingIcon"><?php echo TEXT_PRODUCT_FREE_SHIPPING_ICON; ?></div>
<?php } ?>
<!--eof free ship icon -->
<?php } ?>
<br class="clearBoth" />
<!--bof Add to Cart Box --><DIV style="float:right">
// do nothing
// show the quantity box
<div id="cartAdd">
echo $display_qty;
echo $display_button;
</DIV><!--eof Add to Cart Box-->
<!--bof Attributes Module -->
<!--eof Attributes Module -->
</ul>
if ($products_discount_type != 0) { ?>
* display the products quantity discount
require($template->get_template_dir('/tpl_modules_products_quantity_discounts.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_modules_products_quantity_discounts.php'); ?>
<?php if (PRODUCT_INFO_PREVIOUS_NEXT == 2 or PRODUCT_INFO_PREVIOUS_NEXT == 3) { ?>
<?php } ?>
if ($flag_show_product_info_reviews == 1) {
if ($reviews->fields['count'] > 0 ) { ?>
<div id="productReviewLink" class="buttonRow back"><?php echo '<a href="' . zen_href_link(FILENAME_PRODUCT_REVIEWS, zen_get_all_get_params()) . '">' . zen_image_button(BUTTON_IMAGE_REVIEWS, BUTTON_REVIEWS_ALT) . '</a>'; ?></div>
<p class="reviewCount"><?php echo ($flag_show_product_info_reviews_count == 1 ? TEXT_CURRENT_REVIEWS . ' ' . $reviews->fields['count'] : ''); ?></p>
<?php } else { ?>
<div id="productReviewLink" class="buttonRow back"><?php echo '<a href="' . zen_href_link(FILENAME_PRODUCT_REVIEWS_WRITE, zen_get_all_get_params(array())) . '">' . zen_image_button(BUTTON_IMAGE_WRITE_REVIEW, BUTTON_WRITE_REVIEW_ALT) . '</a>'; ?></div>
if ($flag_show_product_info_date_available == 1) {
<p id="productDateAvailable" class="productGeneral centeredContent"><?php echo sprintf(TEXT_DATE_AVAILABLE, zen_date_long($products_date_available)); ?></p>
if ($flag_show_product_info_date_added == 1) {
<p id="productDateAdded" class="productGeneral centeredContent"><?php echo sprintf(TEXT_DATE_ADDED, zen_date_long($products_date_added)); ?></p>
} // $flag_show_product_info_date_added
<!--bof Product URL -->
if (zen_not_null($products_url)) {
if ($flag_show_product_info_url == 1) {
<p id="productInfoLink" class="productGeneral centeredContent"><?php echo sprintf(TEXT_MORE_INFORMATION, zen_href_link(FILENAME_REDIRECT, 'action=url&goto=' . urlencode($products_url), 'NONSSL', true, false)); ?></p>
} // $flag_show_product_info_url
<!--eof Product URL -->
<!--bof Form close-->
</form>
