skrill is called moneybooker before.
I download the module on skrill website.
the dubug in cache shows: PHP Parse error: syntax error, unexpected '{' in /******/moneybookers.php on line 54
line 54 should be in these lines.
PHP Code:function moneybookers() {
global $messageStack;
$this->code = 'moneybookers';
$this->codeVersion = '0.0.1.a';
$this->description = 'WELCOME';
$this->title = ($this->check() ? "<b>" : "check") . MODULE_PAYMENT_MONEYBOOKERS_TEXT_MAIN_MODULE . (!$this->check() ? " - <b>" . MONDULE_PAYMENT_MONEYBOOKERS_TEXT_REQUIRED : "required") . "</b>";
try {
if ((int)$this->_get('ORDER_STATUS_ID') > 0) {
$this->order_status = $this->_get('ORDER_STATUS_ID');
$this->sort_order = $this->_get('SORT_ORDER');
if ($this->_defined('STATUS') && (!$this->_defined('EMAIL') || !$this->_get('EMAIL') || !$this->_defined('SECRET_WORD') || !$this->_defined('ID') || !$this->_get('ID'))) {
$this->title .= '<b style="color: red"> (Module is not configured)</b>';
$this->enabled = false;
$this->enabled = $this->_get('STATUS');
} catch (Exception $e) {
// if (IS_ADMIN_FLAG === true) $this->tableCheckup();
* Funkcja sprawdzaj膮ca czy modu艂 jest zainstalowany
* @return bool
