Results 1 to 3 of 3
    Sep 2005
    Hong Kong
    help question Question regarding $manufacturers_id in tpl_product_info_display.php
    Hi everyone,
    In my previous shopping cart (1.3.8) I was able to use these codes in tpl_product_info_display.php to turn the manufacturer name into a link, but now that I'm using 1.5.1 the codes no longer work... It correctly turns into a link but there is nothing at the end of "index.php?main_page=index&manufacturers_id=", which means when I click on the link it redirects me to the homepage.
    I'm not familiar with php so if anyone could help me out that would be greatly appreciated... thanks in advance!
    <?php echo '<li>' TEXT_PRODUCT_MANUFACTURER '<a class="manufacturerlink" href="' zen_href_link(FILENAME_DEFAULT'manufacturers_id=' $manufacturers_id) . '" title="' $manufacturers_name '">' $manufacturers_name "</a></li>\n"?>
    Keywords: manufacturer link, clickable manufacturer name, manufacturer id
    Default Re: Question regarding $manufacturers_id in tpl_product_info_display.php
    Chances are your old site had made changes to the files in /includes/modules/pages/product_info/ and added code in there to retrieve the mfg value and put it into a variable named $manufacturers_id so that it could be output in your template.
    You'll need to re-do that.
    Sep 2005
    Hong Kong
    Thank you, Dr. Byte sensei! I added this line in /includes/modules/pages/product_info/main_template_vars.php and it worked like a charm!
    $manufacturers_idzen_get_products_manufacturers_id((int)$_GET['products_id']);
  1. Replies: 13
    Last Post: 15 May 2015, 05:18 PM
  2. v154 question regarding line 510 of the admin/english.php
    By Thannaree in forum General Questions
    Last Post: 24 Jan 2015, 05:04 AM
  3. Question regarding https in configure.php
    By Hell Guapo in forum Basic Configuration
    Last Post: 2 Nov 2011, 05:03 PM
  4. php help with tpl_product_info_display.php
    By JamesM in forum Templates, Stylesheets, Page Layout
    Last Post: 29 Sep 2010, 08:09 PM
  5. Replies: 0
    Last Post: 13 Oct 2008, 10:08 AM
