    Nov 2011
    cart error Setting a max number with a + for items with large stock
    I can`t find a function that I believe must be included in ZC, or can be solved by doing something simple. In my ZC store I show the stock status on each and every product. We have ordered some products in large quantities, and we really don`t want to show the whole stock. Many stores have the simple solution of having a "max" value on stock so instead of "* 105 units in stock", it says "20+ units in stock" (if the max limit is set to 20).
    Can anyone point me in the right direction here?
    Default Re: Setting a max number with a + for items with large stock
    That's normally in a group of <li> tags in the tpl_product_info_display.php template.
    If your PHP skills are up to the task, you can write your customization right there.
    Nov 2011
    Ok - thought maybe this was a setting in the admin system as this is quite common presentation of stock.
    I know how to read and search php (I understand programming), but sadly I am not able to write php code. I guess this is the code that needs to be changed:
      <?php echo (($flag_show_product_info_quantity == 1) ? '<li>' $products_quantity TEXT_PRODUCT_QUANTITY '</li>'  '') . "\n"?>
    Can anyone rewrite this code for me so that if products_quantity > 20, it shows "20+" instead of the actual number?
    Sure ...
    <?php echo (($flag_show_product_info_quantity == 1) ? '<li>' . (($products_quantity > 20) ? '20+' : $products_quantity) . TEXT_PRODUCT_QUANTITY . '</li>'  : '') . "\n"; ?>
    Nov 2011
    Thanks!!
    @lat9, thanks for posting the code. I was away from my development code when I posted earlier so I couldn't post any examples!
  1. v151 Loaded large number of product with Easy Populate now multiple images on each product
    By swdynamic in forum All Other Contributions/Addons
    Last Post: 8 May 2015, 08:31 PM
  2. Setting a quantity discount with items with varying attributes?
    By xtina in forum Setting Up Categories, Products, Attributes
    Last Post: 19 May 2010, 12:08 AM
  3. Setting up 1 product with multple sizes - reduce stock item for that size?.
    By lizord in forum Setting Up Categories, Products, Attributes
    Last Post: 8 Apr 2009, 05:43 AM
  4. Masking items with 0 stock from New Products
    By BekahRuth in forum Setting Up Categories, Products, Attributes
    Last Post: 10 Sep 2007, 12:40 AM
