Thread: XAMPP problems
Results 1 to 10 of 10
    Oct 2013
    United States
    Default XAMPP problems
    I can see this code after transfer hosting. and i can't open product. other setting is okey.
    plz help
    Default Re: I can see this code after transfer hosting. and i can't open product.
    Sounds like your new host is using a more advanced version of PHP and you've run into the short-open tags being deprecated. What version of Zen Cart? What admin-level plugins do you have installed?
    Oct 2013
    United States
    Sir
    i move to xamp server. and my zen cart version is 1.5.1 .
    i can see this code on top and others options work fine
    Oct 2013
    United States
    And my frontend show this code.
    Dec 2010
    UK
    Quote Originally Posted by crixus View Post
    Sir
    Lat9 is spot on...as normal! XAMPP needs you to use full php end tags.
    Search Google for the code that's being displayed or search your template support thread, you'll find the solution (been there done that got the t-shirt). I'll have a look later too.
    Dec 2010
    UK
    Default Re: XAMPP problems
    A well documented issue, here ya go...
    http://www.zen-cart.com/showthread.p...02#post1141102
    Oct 2013
    United States
    Quote Originally Posted by picandnix View Post
    Thanks a Lot. :)
    Gonna send you a nice t-shirt
    Oct 2013
    United States
    [QUOTE=crixus;1223781]And my frontend show this code.
    i find those code.. all from .zencart/admin/filenames.php.
    all code appear top of admin page!
    Oct 2013
    United States
    wow! its work now!
    Dec 2010
    UK
    wow! its work now!
    Nice one
  1. Email setup problems with XAMPP
    By Whogives in forum Installing on a Windows Server
    Last Post: 18 May 2013, 08:12 AM
  2. cURL/SSL problems on XAMPP
    By 10gallons in forum Installing on a Windows Server
    Last Post: 1 Dec 2009, 01:18 PM
  3. Problems accessing test domain running 1.3.8a on XAMPP/Vista
    By escookies in forum Installing on a Windows Server
    Last Post: 14 Jul 2009, 03:31 PM
  4. Problems with XAMPP installation
    By Marlake in forum Installing on a Windows Server
    Last Post: 26 Mar 2008, 07:11 PM
  5. NewB Using Zen Cart Book to install XAMPP-configuration problems!!
    By carlyjcais in forum Installing on a Mac Server
    Last Post: 16 Nov 2007, 07:05 AM
