    Aug 2008
    Southern California
    Default What is a SQL command to change products_model ?
    I know this is wrong and the syntax isn't right, but I'm trying to find the proper sql syntax to change a product model number. We have to update a bunch of numbers and using the SQL command will go a lot easier than using the admin panel.
    I was playing with this, but I know it's just not right:
    UPDATE products SET products_model = '123-NEW' WHERE products_model = '123-OLD'
    Many thanks in advance
    Default Re: What is a SQL command to change products_model ?
    I am not sure where this would be wrong, but if you want to run it from the Install SQL Patches ... you should use:
    UPDATE products SET products_model = '123-NEW' WHERE products_model = '123-OLD';
    And all Products with the products_model of 123-OLD will be changed to 123-NEW ...
    Aug 2008
    Southern California
    Ajeh, thank you! That's it!
    I was only guessing at my own code.
    I can't believe I was that close!
    It worked! Thanks again!
    You are most welcome ... glad to be able to help you out ...
    You were exactly right with your SQL and could have gotten away with it, as is, in phpMyAdmin, but in the Install SQL Patches it requires the semi-colon om the end of each line and a few other rules to follow ...
  1. SQL command to update order status ?
    By Akasashasha in forum General Questions
    Last Post: 4 Mar 2011, 10:02 AM
  2. metatags_title_status - sql command?
    By Kenichi in forum General Questions
    Last Post: 20 Jan 2011, 10:15 PM
  3. SQL command to update category images?
    By Jeff G in forum Setting Up Categories, Products, Attributes
    Last Post: 2 Dec 2009, 10:53 PM
  4. sql command to change values - Canada Post
    By tony_sar in forum Addon Shipping Modules
    Last Post: 14 Mar 2009, 07:49 PM
  5. Basic SQL Update command
    By 0be1 in forum General Questions
    Last Post: 29 Jul 2008, 02:00 PM
