bislewl
There are a couple things going on here.
1.) This mod doesn't say the columns that it should be going into.
2.) It's missing the value of the configuration id this statement should read something like:
INSERT INTO zen_configuration
(configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, last_modified, date_added, use_function, set_function)
VALUES ('Related Products Columns per Row', 'SHOW_PRODUCT_INFO_COLUMNS_RELATED_PRODUCTS', '3', 'Related Products Columns per Row<br />0= off or set the sort order', '18', '100', NULL, now(), NULL, 'zen_cfg_select_option(array(\'0\', \'1\', \'2\', \'3\', \'4\', \'5\', \'6\', \'7\', \'8\', \'9\', \'10\', \'11\', \'12\'),')
