My issue:
I recently installed v1.5.1 via my hosting company script installer. (Called Quick Install)
I was previously running 1.3.9h which was installed via Fantastico.
I want to pull over all products, desccriptions, orders history, and customers to the new installation.
Im not sure if any of the above matters, but I figured that I would at least get out all information.
What I have done:
I searched this forum and found: "http://www.zen-cart.com/showthread.php?166512-Fresh-install-on-new-server-but-want-to-migrate-customers-and-products"
(I made backups of everything, backup of the databases of both the old and newly setup carts as well so that I can go back in case of problems...and thank the lord I did...everything is good on that end.)
I did the database backup of my old working cart (139) through the phpMyAdmin software in my CPanel dashboard as per the forum thread.
I then put that database into where the new carts database was.
I also uploaded the file "fix_cache_key.php".
Outcome:
Once I did the above, when I go into my browser to actually see the cart, I get this:
"WARNING: An Error occurred, please refresh the page and try again"
I even tried to follow the "fix_cache_key.php" file and to no avail, nothing will show up and I just get the same error. If I want to actually get back into the admin panel, I have to go into phpmyadmin and restore the backup I made before I started messing with all of this.
Request:
It has been 5 days now of me trying to get this to work. I am getting desperate and would take any advice that I can get on getting this working. Thanks in advance.
