    Dec 2013
    Default Right Column Disapearing When Viewing Product Info
    www.madrobotminiatures.com
    The right column is there for the categories and other pages but not when you click on a specific product. The only change I've made in over a year was just installing a multiple image add-on earlier today.
    Any ideas how I can change that back?
    Default Re: Right Column Disapearing When Viewing Product Info
    Quote Originally Posted by Joe Robot View Post
    Restore the backup you made beforeinstalling the new addon, otherwise, uninstall the addin, or attempt to identify what towards the bottom of the main page is causing the rest of the processing to stop. (Check error log files).
    Dec 2013
    That did it. Just went through and deleted the few files that were added via the install.
    Makes sense now that I did it. Thanks for your help and quick response!
    Welcome. As you continue to modify your store, you hopefully will discover the various. Ways to find how/why things are not going the way they should, and how to merge files without error (for those that require merging).
  1. Specials in Product Info Right Column?
    By Susan101 in forum Templates, Stylesheets, Page Layout
    Last Post: 31 Aug 2011, 03:03 PM
  2. header moves to the right when viewing category- BUT...
    By Stingraynut in forum Templates, Stylesheets, Page Layout
    Last Post: 10 Dec 2010, 05:47 AM
  3. removing right column on product info pages
    By aoren in forum Templates, Stylesheets, Page Layout
    Last Post: 14 May 2010, 04:09 AM
  4. Right hand column missing on product info pages
    By spbennett in forum General Questions
    Last Post: 12 Jul 2007, 07:05 AM
