Results 1 to 9 of 9
    Jul 2009
    Arkansas
    Default Some products not showing up in store
    If this has been covered could someone send me the link, I caught myself looking but at my age I could have gone right past it.
    Using Apsona, I just uploaded one suppliers products to my store, the datafile I copied into Apsona to upload had 3611 items. I didn't receive any errors and everything looked like it went ok. Using Apsona again, I just exported a csv file from my store to check on a couple other things I was working on and got to looking at it and noticed there were only 3429 products from that supplier in the csv file. I'm missing the other 183 that looked like they were uplaoded.
    Like I said, I didn't receive any errors while uploading, where would I start looking to try to find out why those 183 didn't upload or at least not showing up?
    Thanks for any help,
    Jim
    Jim Stiles
    http://www.missyscollectibles.com
    Coming home to Zen Cart!
    Default Re: Some products not showing up in store
    Go to phpMyAdmin ...
    Browse the table:
    products
    and ensure that all Product Records contain a:
    master_categories_id
    that is greater than 0 ...
    Check that all Products have a Product Description ... go to phpMyAdmin and run the SQL of:
    select p.products_id, p.products_date_added, p.products_last_modified
    from products p
    left outer join products_description pd on p.products_id = pd.products_id
    where pd.products_id is null;
    Does anything show up?
    Try checking to see if any products_id is missing from the products_to_categories table ...
    Go to phpMyAdmin and in the SQL run:
    select p.products_id, ptoc.categories_id
    from products p
    left outer join products_to_categories ptoc on p.products_id = ptoc.products_id
    where ptoc.products_id is null;
    Jul 2009
    Arkansas
    Hi Linda,
    Not being to familiar with running sql stuff, I checked with Hostgator and they told me how to do it but also ran the ones that you suggested and here is the reply they suggested I reply back to you with.
    Thanks for your help,
    Jim
    Their reply:
    mysql> select p.zc_products_id, p.zc_products_date_added, p.zc_products_last_modified from zc_products p left outer join zc_products_description pd on p.zc_products_id = pd.zc_products_id where pd.zc_products_id is null;
    ERROR 1054 (42S22): Unknown column 'p.zc_products_id' in 'field list'
    mysql> select p.zc_products_id, ptoc.zc_categories_id from zc_products p left outer join zc_products_to_categories ptoc on p.zc_products_id = ptoc.zc_products_id where ptoc.zc_products_id is null;
    Jim Stiles
    You added too many zc_ ...
    Try using:
    from zc_products p
    left outer join zc_products_description pd on p.products_id = pd.products_id
    from zc_products p
    left outer join zc_products_to_categories ptoc on p.products_id = ptoc.products_id
    Jul 2009
    Arkansas
    I sent Hostgator your previous instructions as it's all still greek to me, their reply is below. Do you think it would correct the situation if I just uploaded a new csv file with these missing items on it and upload them as new and not updated?
    Thanks for the help,
    Jim
    Their reply......
    Thank you for your reply. It looks like the query they provided is different from the one before:
    select p.zc_products_id, p.zc_products_date_added.....
    versus:
    select p.products_id, p.products_date_added....
    It seems that the tables don't necessarily have zc_ in front of them.
    When I ran one of the queries they provided it returns results:
    [root@gator2008 /home2/jstiles/public_html]# mysql jstiles_zncr1 -e "select p.products_id, ptoc.categories_id
    > from zc_products p
    > ptoc.products_id
    > where ptoc.products_id is null;"
    Warning: Using unique option prefix pass instead of password is deprecated and will be removed in a future release. Please use the full name instead.
    | products_id | categories_id |
    | 206 | NULL |
    | 207 | NULL |
    | 208 | NULL |
    | 209 | NULL |
    ....and so on.
    Jim Stiles
    I am thinking that you have possibly invalid categories_id in the products_to_categories table as none should be blank, NULL or set to 0 ...
    You might try backing up your database and redoing the update from your cvs but I do not use tings to import Products so I really cannot tell you the "best" solution ...
    Perhaps contacting Apsona about your issues might be a solution, or posting on the support thread for it ...
  1. v150 Products not showing up in SOME categories
    By iconicity in forum Setting Up Categories, Products, Attributes
    Last Post: 24 Jul 2012, 07:41 AM
  2. Some products not showing...
    By WayOnHigh in forum Setting Up Categories, Products, Attributes
    Last Post: 10 Nov 2009, 05:32 PM
  3. Store pickup for some products and not others
    By Sushigal in forum Built-in Shipping and Payment Modules
    Last Post: 29 Apr 2009, 11:48 AM
  4. Bank module - some orders not showing in my store
    By ellivir in forum Addon Payment Modules
    Last Post: 27 Jan 2009, 08:25 AM
  5. Some Products not showing in catagories
    By gardengirl in forum General Questions
    Last Post: 31 Jul 2008, 03:42 PM
