I am getting the following error "WARNING: An Error occurred, please refresh the page and try again." when I try to upload / send an sql file. When I looked in my debug file I got the following
"PHP Fatal error: 1062
uplicate entry 'COLUMN_WIDTH' for key 'unq_config_key_zen' :: INSERT INTO zc_configuration (configuration_id, configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, date_added, use_function, set_function) VALUES (NULL, '<font color="#0044ff">ACTIVATE Responsive Template by selecting Column Widths</font>', 'COLUMN_WIDTH', '2', 'Width of the Left and Right Columns<br />0 = Use Default Template Settings<br />1 = 75px<br />2 = 150px<br />3 = 225px',@configuration_group_id, NULL, NOW(), NULL, 'zen_cfg_select_option(array(\'0\', \'1\', \'2\', \'3\'),'); in /home3/firstcap/public_html/zencart/includes/classes/db/mysql/query_factory.php on line 120"
What do I need to do to fix this so I can continue.
Any help / guidance is greatly appreciated.
Mark
