Results 1 to 10 of 16
    Default Problem with items with attributes
    I have a group of products on my website with specific attributes. I think I have set them up correctly. People can add them to their shopping basket ok but when they try and check out they get the following message.
    Here are the items in question. Disregard the first product as I had to remove the attributes to allow someone to place their order. http://www.spottycupcakes.co.uk/inde...index&cPath=80
    I have checked my logs and this is what is recorded. Anyone know what I should do (bearing in mind I'm a complete novice at this)?
    [01-Feb-2014 20:41:22 Europe/London] PHP Fatal error: 1064:You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ':e9884d55e58e203da17a351accf67ead, 198) AND po.products_options_name = "Minimum ' at line 1 :: SELECT ifnull(max(pov.products_options_values_sort_order), 0) as postage_attribute FROM products_options_values pov INNER JOIN products_attributes pa ON pov.products_options_values_id = pa.options_values_id INNER JOIN products_options po ON po.products_options_id = pa.options_id WHERE pa.products_id IN (250, 182, 215:e9884d55e58e203da17a351accf67ead, 198) AND po.products_options_name = "Minimum Delivery Method:" in /home/spott698/public_html/includes/classes/db/mysql/query_factory.php on line 120
    Many thanks in advance.
    Apr 2007
    Ontario, Canada
    Default Re: Problem with items with attributes
    Just placed a test order on your site with the items in question, no errors. Which one specifically caused this?
    Twitch.
    https://www.twitchtoo.com Do you work for free? Please donate.
    Twitch Base8 - Obsidian - This, is what's new.
    This one for example http://www.spottycupcakes.co.uk/inde...8e5bae8b127c6a
    It can be added to the basket but when you try and checkout the error message comes up.
    P.s. I see that you have placed a test order did you not encounter any problems at all?
    Feb 2005
    Lansing, Michigan USA
    Works OK for me, too (Jim Dandy).
    I have no idea what is going on then. I had two customers this evening report the same problem which is why I tried it out. I can't even get to the checkout never mind place an order.
    Thanks for taking the time to test it. I don't know what is wrong then.
    Ok, I set up a dummy account registered to the US and I can check out no problem. Does anyone know why this fault is only occurring with UK accounts?
    Sorry for all the updates but I'm just posting them in the hope that someone can help.
    I removed the shipping modules I have installed ie "Royal Mail 1st Class "Large Letter" ver. 3.2.0" just leaving me with store pickup and I can check out using that.
    I think I have narrowed it down to that. If I can't get it fixed I will have to list each option individually which isn't ideal but my only option.
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by SpottyCupcakes View Post
    No problems the first time, no problems with the product you specified, check order #9 :)
    Twitch.
    Quote Originally Posted by twitchtoo View Post
    Thanks again for testing. I think it is a problem with UK shipping. All UK orders can be processed if I remove UK shipping options from my admin panel and store pickup is the only option remaining. I think this is why the US orders are being processed as the only option is Store Pickup.
  1. Problem with attributes set with Display Only
    By canemasters in forum Setting Up Categories, Products, Attributes
    Last Post: 4 Apr 2012, 11:02 PM
  2. Problem with Required attributes after moving attributes to product listing page
    By bigmo337 in forum Setting Up Categories, Products, Attributes
    Last Post: 20 Jun 2010, 12:03 AM
  3. Setting a quantity discount with items with varying attributes?
    By xtina in forum Setting Up Categories, Products, Attributes
    Last Post: 19 May 2010, 12:08 AM
  4. Problem with products with attributes stock
    By bubblegumgoods in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 24 May 2008, 10:26 AM
  5. Problem with attribute images with text attributes...
    By aaelghat in forum Setting Up Categories, Products, Attributes
    Last Post: 17 Mar 2008, 04:46 PM
