Results 1 to 3 of 3
    Feb 2007
    Default PHP Fatal error: 0:DB_ERROR_NOT_CONNECTED and There seems to be a problem connectin
    My version is 1.3.9 - I know it needs to be upgrade, but it's a lightly used site.
    Anyway, in my zeal yesterday, I was cleaning up my hosting and deleted the user for the zen-cart database. I added the name back along w/ the original password, made sure it matched both config files.
    And,
    I'm still receiving this error when I try to get into the admin:
    PHP Fatal error: 0B_ERROR_NOT_CONNECTED :: select * from project_version WHERE project_version_key = 'Zen-Cart Database' in D:\HsHome\***\***\store\includes\classes\db\mysql\query_factory.php on line 101and when I go to the main sitehttp://***.com/store/nddbc.htmlI tried clearing the cache, looking at it on a different computer, etc. So before I bug tech support, I thought I'd check here to see if some flag was set that needs to be reset (ok, wishful thinking)ThanksMichelle
    Default Re: PHP Fatal error: 0:DB_ERROR_NOT_CONNECTED and There seems to be a problem conne
    No flags to clear; you just need to make sure that you've set the username and password (both are case-sensitive) properly in your hosting account so that they match the values presently in your /includes/configure.php and /YOUR_ADMIN/includes/configure.php files. You should probably also check that the database itself, as named in the configure.php file, also exists.
    The fact that the database access used to work on both admin- and store-side but now works on neither points to a mismatch in database credentials on your hosting.
    Aug 2011
    I want to give you a BIIIIIIIIIIIIIIIIIIIG hug Lat9 !
    I was so much in tension... now all is well !!
    Thank You So very much !
  1. v151 PHP Fatal error: 0:DB_ERROR_NOT_CONNECTED
    By sammirah in forum Upgrading to 1.5.x
    Last Post: 24 May 2016, 11:01 PM
  2. v150 There seems to be a problem connecting to our database
    By rainbow_pixie_star in forum General Questions
    Last Post: 4 Mar 2016, 07:38 PM
  3. Replies: 1
    Last Post: 10 May 2013, 01:35 PM
  4. There seems to be a problem connecting to our database.
    By janelle in forum General Questions
    Last Post: 12 Sep 2012, 09:05 AM
  5. There seems to be a problem connecting to our database
    By carjamz in forum General Questions
    Last Post: 28 Feb 2009, 11:30 PM
