Can anyone help please?
I'm fairly new to zen cart but I've been setting up a new shop and I'm finding my way around things fairly easily - so far so good - until I have been loading all my products onto the site and noticed an issue I am not sure how to solve.
Basically, all my products titles have a name followed by a product code, e.g. 'Product Title PT0001', 'Product Title PT0002', 'Product Title PT0003' and so on.
The problem I am having is that when setting up a new products within the 'Catalog/Categories/Products' I am assigning a sort number to each product so that they will be listed everywhere according to this number. I am using multiples of 10 for each item so that I can insert a few more products in between each one in the future.
This seems to work fine in the list of products within the 'Catalog/Categories/Products' in the backend admin however, when I go to a product page and view the product counter (e.g. Product 1/72) and use the 'Previous' or 'Next' buttons, the order is all over the place. For instance, it might say Product 3/72 and the be showing product 37, and when next is clicked, it will jump to something like Product 56/72 and show product 4! There seems to be no logic to it.
If I view the products in a list view on the front end it all looks fine again.
I noticed when setting my attributes in the 'Catalog/Attributes Controller' that when I select a list of products from the Category options, that the list is not in the order I specified for those products when setting them up in 'Catalog/Categories/Products'.
They come up in this list as per the number assigned in the product counter on the front end, i.e. if it says Product 7/72 on the Product page (front end) it also appears as the 7th item on the list within the 'Catalog/Attributes Controller' list.
Sooooo (and thanks for sticking with it so far), the question is, how do I get everything to list as per the order I selected when setting up the product in 'Catalog/Categories/Products' originally? I don't necessarily want the product counter number to tie in with the actual product code as I will be adding more products in between current ones and I know this would knock that out, but I would like customers to be able to click through rodents in the sequence I want them to, i.e 1,2,3,4,… and not 1,5,34,65,23,…
Any help would be gratefully received.
Many thanks
Jo
