Well, I have a missing order. PP went through fine but I cannot locate the order or the transaction ID in any of the database files (checked back office first and did not find anything) via SQL. I have only an amount, PP transaction ID and the zenID from PP. There are NO order numbers skipped period. How do I go about looking further than looking for the last name in the order tables and the PP Transaction number in the PP tables??Code:Server Information Server Host: server.radiant-holidays.com (162.144.60.198) Database Host: localhost (127.0.0.1) Server OS: Linux 2.6.32-431.3.1.el6.x86_64 Database: MySQL 5.5.36-cll Server Date: 03/11/2014 18:51:40 Database Date: 03/12/2014 00:51:40 Server Up Time: 00:51:40 up 44 days, 2:29, 0 users, load average: 0.00, 0.15, 0.14 HTTP Server: Apache PHP Version: 5.3.26 (Zend: 2.3.0) PHP Memory Limit: 128M PHP Safe Mode: Off PHP File Uploads: On Max Size: 50M POST Max Size: 10M Database Data Size: 10,410 kB Database Index Size: 2,196 kB
As for the Subtotal and Totals, the amounts listed in the Admin do not match. If you add up the extended amounts, the total is off by over $13? How would I go about looking for this problem??
I did check my PP info in the Payment Module to make sure that has not been hacked.
