    Feb 2010
    Default Easy Populate Problem
    I am not sure what I did but could use a little help / advice.
    I had about 700+ products in my shop and about 7000 more to put on. I spent 2 days copying/pasting/arranging my suppliers CSV files into a master csv for use with easy populate.
    When I finally finished, I went back into my zen cart, deleted all the categories I had already made and uploaded the CSV through easy populate.
    Now, in my admin section, I see everything correctly. All the categories, sub categories and items in each category are correct.
    However, when I go to my shop, even though all the categories are listed in the menu correctly, if I try to go to any of them, I get a page not found error. None of the links work.
    I have, for example, Books & Journals as a main category with about 10 sub-cat's in it.
    On my menu, I see Books & Journals, and all the sub-cat's, but if I click it, it goes to: 5/all-amulets-talismans, not to Books & Journals.
    They are all like this, wrong name on each link.
    Any idea what could have happened? I have my CSV set up correctly with category 1 for main, 2 for sub, 3 for sub-sub ...etc, so they should have shown up correctly!
    Dec 2010
    UK
    Default Re: Easy Populate Problem
    You are using a URL rewriting tool?
    Feb 2010
    I am using super simple SEO url rewrite mod.... yes.
    Dec 2010
    UK
    Quote Originally Posted by jax2 View Post
    This version? http://www.zen-cart.com/downloads.php?do=file&id=1754
  1. v150 Easy Populate 4 vs. Easy Populate CSV - What's going on with so many Easy Populates?
    By oleancomputers in forum All Other Contributions/Addons
    Last Post: 20 Jun 2013, 05:58 PM
  2. Easy populate problem
    By rwslippey in forum All Other Contributions/Addons
    Last Post: 20 Aug 2010, 07:59 PM
  3. Easy Populate Problem
    By webmiss in forum All Other Contributions/Addons
    Last Post: 30 Jan 2010, 02:55 AM
  4. Easy Populate problem
    By imcsk8 in forum Addon Payment Modules
    Last Post: 29 Oct 2009, 08:20 AM
