    May 2014
    NJ
    Default Weird Issue with Detailed Product Page & Images
    Hey there,
    We are having this issue when you click on product in a category or a designer's store.
    Do you have any idea why this is happening and how to fix it?
    I have attached screen shots of what it should look like and what it does look like. I can only get to what it "should" look like by hitting the "stop" button on the browser before the page fully loads. I am sorry if this doesn't make any sense. I tried to explain it as best as I could.
    I have the image handler installed and have for a while and it was working fine but this only started happening about a week ago. So I am not sure if it could be that.
    Any help?
    My website: http://thescrapnerds.com
Name:	Screen Shot 2014-07-01 at 3.35.54 PM.jpg
ID:	14225   Click image for larger version.
Name:	Screen Shot 2014-07-01 at 3.35.36 PM.jpg
    Default Re: Weird Issue with Detailed Product Page & Images
    It appears that your java script is being called and taking over
    I don't know about your product info page, but the homepage with product listing jumps when you hover on the last item in a row. This will be caused by the hovered item's borders/margin/height decreasing on hover, and "catching" the following <li> item which is trying to float or slide to the left beneath it. If you want to fix that, you will need to identify the style rule(s) which apply to it in the ordinary and hovered state, and make sure they have the same effective dimensions.
    May 2014
    NJ
    Do you have any idea how I could stop this from happening?
    May 2014
    NJ
    Thank you! I never noticed this issue. I will look into this.
    Start by switching to the classic template if this works correctly then look at all of the js that your template is loading
  1. v150 Trouble with product images - showing up weird on product listing pages.
    By schapirate in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Apr 2012, 06:25 PM
  2. weird issue with master category in product page
    By willie bee in forum Setting Up Categories, Products, Attributes
    Last Post: 21 Nov 2011, 03:42 PM
  3. Replies: 2
    Last Post: 14 Jun 2010, 08:04 PM
  4. Weird issue with product types
    By pasi in forum Setting Up Categories, Products, Attributes
    Last Post: 5 Nov 2008, 08:46 AM
  5. Moved, weird issue with logging in
    By bonni in forum Installing on a Linux/Unix Server
    Last Post: 20 Oct 2006, 10:06 PM
