    Jul 2007
    Sunny Cornwall
    Idea or Suggestion Problems with Attribute Images
    Please help,
    I am trying to get the attribute images in rows instead of below each other
    Please see http://displayandboxframes.co.uk/ind...&products_id=1
    any ideas
    Kind regards
    Arthena
    Default Re: Problems with Attribute Images
    You have a statement like this: <br class="clearBoth" />
    That appears after each imaage is displayed. Unless you always want that not to happen, then I would suggest using css to hide the statement. I'm sorry, but at the moment it would be difficult for me to provide the css to do this. (On a cell phone with limited capability.) Otherwise, removing the statement from your override file that would display that list of items would be the way to go, though I would be concerned that removal en mass may provide some unexpected/undesired results.
    It took me a long time to find the setting I knew existed... but look in admin > Catalog > Option Name Manager, "edit" the option name that has the images, and enter your desired quantity for "Attribute Images per Row:". It appears to currently be set to 1.
    Jul 2007
    Sunny Cornwall
    many thanks for the info. Have had a play and it seems to be ok but had to change from a drop down box.
    Will keep trying.
    kind regards
    Arthena
    Quote Originally Posted by arthena View Post
    Will keep trying.
    kind regards
    Arthena
    In that same area that gjh42 so kindly pointed out is a style option for the images. Did you also try adjusting that before moving away from a dropdown? The explanation of what each value means is provided below that, though I somewhat think still that testing the value(s) may be of more benefit than the description.
    Jul 2007
    Sunny Cornwall
    Hi, Thanks for your reply.
    Yes I did have good pay with all the setting but nothing would let the icons display as a group side by side.
    Kind regards
    Arthena
  1. v150 Attribute images not in-line with attribute selection
    By JacobBushnell in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Aug 2012, 11:51 PM
  2. Problems With Attribute Pull Downs and Read Only
    By dj_jj in forum Setting Up Categories, Products, Attributes
    Last Post: 1 May 2012, 10:02 AM
  3. Large Attribute Images - do they cause any problems
    By demiurgia in forum Setting Up Categories, Products, Attributes
    Last Post: 22 Jul 2010, 03:27 AM
  4. Problem with attribute images with text attributes...
    By aaelghat in forum Setting Up Categories, Products, Attributes
    Last Post: 17 Mar 2008, 04:46 PM
