Results 1 to 3 of 3
    Dec 2009
    Scotland
    help question Adding script between <head> tags
    I need to add some script between the <head> tags on the home page to make a picture rotation work. Can anyone tell me the location of the page I need to enter the script in please? I have searched here and not found anything and I have also purchased the Zen Cart book but cannot find it in there either. (Disappointed to see that the index at the back of the book has been dropped for this edition)
    Many thanks in advance
    Tog
    Dec 2009
    Scotland
    Default Re: Adding script between <head> tags
    I found the answer in the similar threads list below (shame that only appears after posting the question) the location is:
    /includes/templates/template_default/common/html_header.php
    Best wishes
    Tog
    Two MUCH BETTER options are:
    a) stick the code into a separate new file:
    /includes/templates/NAME_OF_YOUR_TEMPLATE_FOLDER_HERE/jscript/jscript_picturestuff.php
    or if you're rather directly edit an html file (but that means you have to customize more core files)
    b) instead of touching template_default you should do it in your own customized file for your own template:
    /includes/templates/NAME_OF_YOUR_TEMPLATE_FOLDER_HERE/common/html_header.php
  1. non-english head tags goes out of <head></head>
    By Jerry5763837 in forum General Questions
    Last Post: 5 Jun 2012, 02:21 PM
  2. Replies: 8
    Last Post: 28 Feb 2012, 03:05 PM
  3. I need to place some code between the HEAD tags..
    By Scott_C in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Dec 2009, 05:16 AM
  4. Adding code to <head> tags in ezpages
    By donplay in forum General Questions
    Last Post: 3 May 2009, 05:13 AM
  5. Adding a head tag script
    By gardengate in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Oct 2006, 01:46 AM
