    Mar 2010
    Default Admin login does not default to login but to index
    I just instaled 1.5.3 in a new directory for setup instead of upgrading my old 1.3.8 version. When I go to login ito the Admin example jmw.net/admin/ it goes straight to the admin index page without needing to login. I can logout and it will take me back to the login.php page but if I remove which would default to index.php I am still logged in.
    Default Re: Admin login does not default to login but to index
    Quote Originally Posted by jybwatson View Post
    How was it installed/where did the files come from?
    This has been seen through an installation package that was reworked by someone else/not from this site. (ie: unofficial repackaged automated installers by hosting companies)
    Feb 2005
    Lansing, Michigan USA
    Considering that navigating to jmw.net/admin/ takes me to your store's (wholesale) index page, I'd guess you have some sort or redirect going on.
    Mar 2010
    Thanks, uploaded the zip file and unziped it there, that seemed to work. Such a simple fix and I spent an entire day looking at what might be wrong, thanks again.
    Glad that worked as well.
    I say it that way because, there is a lot that is missing from the discussion of how the above actions were completed. Ie between the plesk install and the upload of the individual files, whether the original files were removed, if there were files not overwritten because the plesk install locked some files, if there were files present from the plesk install that were not included in the ZC install that override the files of ZC, etc...
    Installing by simply uploading the files to a clean slate would work just as well, but glad you're off to making your store usable under 1.5.3!
    Mar 2010
    first install was through my host using plesk, then I used the download I had, unziped it on my computer and loaded them to the server using ftp.
  1. SSL is on, but http:// login page does not redirect to https://
    By jackie.taferner in forum Basic Configuration
    Last Post: 16 Jun 2011, 04:53 PM
  2. admin login does not show
    By lastpirate007 in forum Customization from the Admin
    Last Post: 22 Sep 2010, 12:44 AM
  3. Admin login does not work?
    By svital in forum Installing on a Windows Server
    Last Post: 14 Mar 2010, 06:59 AM
  4. Replies: 7
    Last Post: 22 Aug 2007, 05:42 AM
  5. Admin Login Does Not Display
    By pxsant in forum Installing on a Linux/Unix Server
    Last Post: 19 May 2006, 06:44 AM
