Results 1 to 3 of 3
    Aug 2009
    North Idaho, USA
    Default MyDEBUG: help w QueryFactory errors
    Not really sure where posts related to MyDEBUG files should be started. Maybe a new category is needed in the forum.
    There are a few files, all have PHP Fatal Error: 1062, queryFactory and insert into db_cache_entry_name in the list.
    [11-Aug-2014 04:22:03 America/Los_Angeles] #1 trigger_error() called at [/home/XXXXXXXX/public_html/includes/classes/db/mysql/query_factory.php:155]
    #2 queryFactory->show_error() called at [/home/XXXXXXXX/public_html/includes/classes/db/mysql/query_factory.php:132]
    #3 queryFactory->set_error() called at [/home/XXXXXXXX/public_html/includes/classes/db/mysql/query_factory.php:262]
    #4 queryFactory->Execute() called at [/home/XXXXXXXX/public_html/includes/classes/cache.php:131]
    #5 cache->sql_cache_store() called at [/home/XXXXXXXX/public_html/includes/classes/db/mysql/query_factory.php:239]
    #6 queryFactory->Execute() called at [/home/XXXXXXXX/public_html/includes/classes/category_tree.php:50]
    #7 category_tree->zen_category_tree() called at [/home/XXXXXXXX/public_html/includes/modules/sideboxes/categories.php:19]
    #8 require(/home/XXXXXXXX/public_html/includes/modules/sideboxes/categories.php) called at [/home/XXXXXXXX/public_html/includes/modules/westminster_new/column_left.php:40]
    #9 require(/home/XXXXXXXX/public_html/includes/modules/westminster_new/column_left.php) called at [/home/XXXXXXXX/public_html/includes/templates/westminster_new/common/tpl_main_page.php:208]
    #10 require(/home/XXXXXXXX/public_html/includes/templates/westminster_new/common/tpl_main_page.php) called at [/home/XXXXXXXX/public_html/index.php:97]
    [11-Aug-2014 04:22:03 America/Los_Angeles] PHP Fatal error: 1062uplicate entry 'zc_56bef17b17fbeb6627441de26659411d' for key 'PRIMARY' :: insert into db_cache set cache_entry_name = 'zc_56bef17b17fbeb6627441de26659411d',
    cache_data =
    [10-Aug-2014 08:58:49 America/Los_Angeles] #1 trigger_error() called at [/home/XXXXXXXX/public_html/includes/classes/db/mysql/query_factory.php:155]
    #6 queryFactory->Execute() called at [/home/XXXXXXXX/public_html/includes/init_includes/init_db_config_read.php:19]
    #7 require(/home/XXXXXXXX/public_html/includes/init_includes/init_db_config_read.php) called at [/home/XXXXXXXX/public_html/includes/autoload_func.php:48]
    #8 require(/home/XXXXXXXX/public_html/includes/autoload_func.php) called at [/home/XXXXXXXX/public_html/includes/application_top.php:158]
    #9 require(/home/XXXXXXXX/public_html/includes/application_top.php) called at [/home/XXXXXXXX/public_html/index.php:26]
    [10-Aug-2014 08:58:49 America/Los_Angeles] PHP Fatal error: 1062uplicate entry 'zc_cc21d2f64edffccfe06d12dd3327bf64' for key 'PRIMARY' :: insert into db_cache set cache_entry_name = 'zc_cc21d2f64edffccfe06d12dd3327bf64',
    cache_data =
    [09-Aug-2014 13:55:23 America/Los_Angeles] PHP Fatal error: 1062uplicate entry 'zc_cc21d2f64edffccfe06d12dd3327bf64' for key 'PRIMARY' :: insert into db_cache set cache_entry_name = 'zc_cc21d2f64edffccfe06d12dd3327bf64',
    cache_data =
    Rick
    RixStix (dot) com
    aka: ChainWeavers (dot) com
    Feb 2012
    mostly harmless
    Default Re: MyDEBUG: help w QueryFactory errors
    Usually a "timing" issue... The more "stress" a server is under, the higher the probability this error will occur... Not really worth getting into the details (do a search of "db_cache site:zen-cart.com" in a search engine if you really want to read more).
    If you see these messages in your error logs more then once a month, it would probably be best to just disable the SQL CACHE by editing your "configure.php" files and setting SQL_CACHE to "none".
    NOTE: There are a few proposed long term fixes, but most involve using some form of database locking / transactions. This would probably require using InnoDB, sqlite, or something similar (on hosts supporting these)...
    Aug 2009
    North Idaho, USA
    TNX for the response. Since upgrading to 1.5.3, it's appearing in the folder at least daily. We'll leave it as-is and see if the host updating PHP and MySQL in the next day or so makes a difference. If not, then change it to none as you suggest.
    Rick
    RixStix (dot) com
  1. v153 Multiple myDEBUG files, similar errors
    By RixStix in forum Bug Reports
    Last Post: 21 Aug 2014, 08:22 AM
  2. v153 myDEBUG: USPS quote errors
    By RixStix in forum Addon Shipping Modules
    Last Post: 20 Aug 2014, 03:38 AM
  3. Replies: 4
    Last Post: 19 Jan 2013, 05:47 AM
