Results 11 to 20 of 23
    Apr 2007
    Dayton, Ohio
    Default Re: USPS Standard Post Setting is not returning rates
    It would seem as if Priority is still at least comparable or less expensive than UPS these days. When you have multiple sizes and weights trying to figure out a USPS only solution is just not that simple. After I debate how i am going to do this, I will post the results.Hopefully I can save others from this same delimna.
    Apr 2007
    Dayton, Ohio
    OK this UPS was very easy to set up, didn't even require an account. What I decided to do was ship USPS priority for smaller and lighter packages (based upon weight) and then for anything over 10lbs. Use only UPS. Here are my new USPS settings:
Name:	Shipping Settings1.jpg
    As you can see there are no settings for anything over 10 lbs.
    Next I installed the UPS module and just checked ground service. I also set the sort order for USPS to 10 and for UPS for 20. When any items over 10 lbs is added to the cart UPS only shows. When any item under 10lbs are added both shipping options show (USPS and UPS). However, the UPS quote is almost always higher and slower to ship, so I doubt anyone will select it for lighter items unless they dont care paying about more and are not concerned with delivery time.
    This seems to be the best alternative for me. I just have to remember my weights for small items, so I know which priority box they fit in. For example if I have a larger item but it only weights 1 lb. I might make the weight 6 lbs to force this item into the larger priority box.
    Hope this helps others!
    Be aware that the First-Class Large Envelopes is not working correctly with USPS at this time ... USPS is aware that they have an issue ...
    If you mark that all Products are Machinable and the weight is 6+ ounces, 0.375lbs, then you will see First-Class Large Envelopes ... Their suggestion is First-Class Parcel but this is not a very good match either ...
    When you have a change, can you switch to the USPS Test Server for just a few tests and see if the First-Class Large Envelope is working correctly for you?
    Apr 2007
    Dayton, Ohio
    I tried it in both test and production and it does not show. I have it enabled First-Class Large Envelope again and this test product is within the weight range (http://www.coolsteratvparts.com/engi...test-p-53.html). The rate does not return in my shipping calculator test, but I will leave the product up for now and first class enabled, so you can test if you wish.
    While set to the USPS Test Server, if you turn on the USPS Debug Log, can you test this product in the cart and then Zip the shipping debug log in the /logs directory that is generated and attach it to your post?
  7. #17
    Apr 2007
    Dayton, Ohio
    I had to zip the file in order for the upload to accept. It is attached. I tested for Dayton Ohio (45305).SHIP_usps_Debug_10092014191251_US_45305_0lb_9oz.zip
    P.S. And I left it in test mode just in case you want to test. I can always re-upload the new log file if you need it.
  8. #18
    Could you PM me your USPS user id?
  9. #19
    I do not believe that your USPS Web Tools User ID is activated ...
    Please contact USPS and have them activate that for you:
    Call USPS 1-800-344-7779 and ask them to ensure that your Web Tools User ID is valid and working for both the Production and Test Server ...
  10. #20
    Apr 2007
    Dayton, Ohio
    Ajeh,
    I actually did call them when I had a problem during set up (I think it was a few weeks to a month ago), and asked them to active me. The rep told me that I was already activated as stated per the e-mail. I told the rep to double check becuase I was having issues and she assured me it was activated. Plus, if you add heavier items to my cart you will see shipping quotes from USPS. I just turned the 0 - 2lb priority back on so you will likely see this quote now.
    Perhaps its not working for test, but it shows results for production. I tried to call but they were closed. Maybe tomorrow when I get a chance I will call them and ask them to make sure I am actived on the test (as well as production) just to be sure.
  1. v151 USPS not returning rates with specific product combinations
    By sports guy in forum Addon Shipping Modules
    Last Post: 21 Dec 2014, 05:27 PM
  2. v151 USPS standard post shipping is not showing up
    By Dashizna in forum Addon Shipping Modules
    Last Post: 3 Mar 2014, 06:59 PM
  3. v139h USPS Shipping Module Not Returning Rates
    By WiccanWitch420 in forum General Questions
    Last Post: 10 Feb 2014, 05:23 AM
  4. v150 Canada Post Module Not Returning Rates for me
    By DJLQD in forum Addon Shipping Modules
    Last Post: 15 Jun 2012, 06:03 AM
  5. USPS api rates: All foreign and domestic rates correct except for Airmail Letter Post
    By dharma in forum Built-in Shipping and Payment Modules
    Last Post: 23 Nov 2006, 02:57 AM
