Thread: SSL Problem
Results 1 to 10 of 14
    May 2011
    Tennessee
    Default SSL Problem
    I have an SSL via GoDaddy.
    If I enter my address https:tennesseetraditionalflies.com it starts the https:/tennesseetraditionalflies.com
    I added the following in my configure.php files
    define('HTTP_SERVER', 'https://tennesseetraditionalflies.com');
    define('HTTPS_SERVER', 'https://tennesseetraditionalflies.com');
    However the http:tennesseetraditionalflies.com does not go to https:tennesseetraditionalflies.com
    Does anyone have any ideas what is causing this?
    Feel free to take a look at the website.
    N of San Antonio TX
    Default Re: SSL Problem
    Is this in the includes/configure.php or the YOUR_ADMIN/includes/configure.php? Not a good idea to have them both https: in the catalog.
    What have you answered for the
    define('ENABLE_SSL', 'true');
    Everything seems to be working correctly in the catalog.
    A little help with colors.
    The other thing to realize is that ZC is coded to use the applicable HTTPS_SERVER setting at the point(s) where such would be necessary like login, financial information, etc... I understand that https: has been applied possibly to the HTTP_SERVER constant both store and admin side, but generally speaking there is no reason to have the entire store securely served.
    May 2011
    Tennessee
    Yes that code is in the configure.php
    May 2011
    Tennessee
    Are you telling that it is functioning properly?
    May 2011
    Tennessee
    GoDaddy SEO reports that it is not protected and it displays all of the http pages as not using SSL.
    Feb 2005
    Lansing, Michigan USA
    Your site is operating properly. Only those pages which require SSL have it. If GoDaddy is looking for SSL on all pages, they don't understand how Zencart works.
    May 2011
    Tennessee
    It appears that putting the defines in the configure.php only work on a Windows server. On a Linux server you need to put the redirect in the .HTACCESS file. Refer to the GoDadday article below.
    https://support.godaddy.com/help/art...le=en&ci=46061
    After making the changes it works now.
    Feb 2005
    Actually, it doesn't. Having the entire site operate under SSL isn't necessary or useful, regardless of what Google is saying. As mentioned, Zencart automatically secures those pages which need it, no redirects needed.
    Australia
    A little offtopic, but......
    Much to my chagrin, I recently read somewhere that Google have plans to give SSL enabled sites higher rankings than non-SSL sites.
    Has anyone else heard about this?
    RodG
  1. SSL problem
    By RCG in forum Installing on a Linux/Unix Server
    Last Post: 24 Oct 2009, 03:33 PM
  2. SSL problem
    By MissKafra in forum Installing on a Windows Server
    Last Post: 21 Jun 2008, 08:27 PM
  3. SSL problem
    By kinget in forum Basic Configuration
    Last Post: 7 Sep 2007, 10:00 AM
