Results 1 to 10 of 10
    Dec 2014
    Default Cannot get Store Pickup to stay selected on final order total before Confirm Order
    This is a fresh install, and I am not live yet because I am working through all my issues and custom configurations first. I am doing all test orders for different customer scenarios. However, I can not get Store Pickup to stay selected on the final checkout page before confirming. It shows up as a possible shipping selection on Checkout Step 2 of 3 page with the other selection Flat Rate. It always defaults to Flat Rate. It never defaults to Store Pickup. I can select Store Pickup as the chosen radio button, but then when I click Continue and go to Checkout 3 of 3 page, it switches to Flat Rate. I cannot get it to stay on Store Pickup! This is not good, because some customers will not want shipping at all and want to pick up their products at the store. At this rate, I am not able to know if they want Store Pickup, just looking at their checkout results. Am I doing something wrong in the setup of the products or shipping modules, or configuration settings??? I have no idea where to start digging to look for the solution to this problem. I have Stirling Grand template and Fast and Easy Checkout installed. I am using the latest ZC version 1.5.3. In Modules > Order Total > Shipping, I have Shipping set to "Free shipping for orders over $100". But that does not seem to affect anything. I am testing with orders way under $100, and it still does not work properly. I can let you know any more configuration settings that you need to know, and also let you look at my shopping site. Please help!
    Default Re: Cannot get Store Pickup to stay selected on final order total before Confirm Orde
    If you turn off Fast And Easy Checkout, and instead use the default checkout flow, does it work properly once again?
    Dec 2014
    Yes. But if I turn off FEC, then I don't have Guest Checkout, and guest checkout is a requirement.
    If you've got a problem caused by FEC, then I suggest contacting Numinix for assistance with whatever is broken because of their plugin.
    Feb 2006
    Tampa Bay, Florida
    Is there a Config for FEC (Under Admin->Configuration->FEC) which indicates the shipping modules that are permitted?
    Dec 2014
    No. Should there be?
    Feb 2006
    Tampa Bay, Florida
    No - for some reason I though I recalled there being one, but there isn't.
    You'll have to go to Numinix, as Dr. Byte suggested.
    Dec 2014
    Default Using Fast and Easy Checkout, can't get Store Pickup to stay selected on Order Total
    For some reason, I cannot get Store Pickup to stay selected on final order total before confirming the order. I have a fresh install of 1.5.3, and I am not live yet because I am working through all my issues and custom configurations first. I am doing all test orders for different customer scenarios. Store Pickup shows up as a possible shipping selection, along with Flat Rate on Checkout Step 2 of 3 page. It always defaults to Flat Rate. It never defaults to Store Pickup. I am able to select the Store Pickup radio button, but then when I click Continue and go to Checkout 3 of 3 page, it switches to Flat Rate. I cannot get it to stay on Store Pickup! This is not good, because some customers will not want shipping at all and want to pick up their products at the store. At this rate, I am not able to know if they want Store Pickup, just looking at their checkout results. Am I doing something wrong in the setup of the products or shipping modules, or configuration settings? I have no idea where to start digging to look for the solution to this problem. I have Stirling Grand template and Fast and Easy Checkout installed. In Modules > Order Total > Shipping, I have Shipping set to "Free shipping for orders over $100". But that does not seem to affect anything. I am testing with orders way under $100, and it still does not work properly. I can let you know any more configuration settings that you need to know, and also let you look at my store site. I need help from Numinix.
    Default Re: Using Fast and Easy Checkout, can't get Store Pickup to stay selected on Order To
    I believe others have had the same problem with FEC.
    Best to contact Numinix to get them to fix it.
    Dec 2014
    Thank you. I didn't mean to post the same issue twice, by the way. ;)
  1. v151 login get error blank page after install fast and easy checkout
    By louisapple in forum General Questions
    Last Post: 19 Jun 2015, 02:25 AM
  2. v150 Product Attributes Not Selected in Cart using Fast and Easy AJAX Checkout 2
    By robwisner1969 in forum General Questions
    Last Post: 4 Dec 2014, 09:39 PM
  3. Replies: 0
    Last Post: 13 Dec 2011, 12:09 AM
  4. Caught in weird PayPal Loop using Fast and Easy Checkout!
    By eyal8r in forum All Other Contributions/Addons
    Last Post: 3 Apr 2010, 01:44 AM
  5. can anyone help me get dirbank mod to work with Fast & Easy Checkout?
    By lankeeyankee in forum Addon Payment Modules
    Last Post: 21 Nov 2007, 05:09 AM
