try to add dimensions to my fedex module, this piece of code is from another module that uses the fields i want to use
foreach ($products as $product) {
$data = $db->Execute(
"SELECT products_freightquote_length, products_freightquote_width, products_freightquote_height " .
"FROM " . TABLE_PRODUCTS . " " .
"WHERE products_id = " . (int)$product['id'] . " " .
"LIMIT 1"
Been try to add it in here with no luck
* Ceon Advanced Shipper Fedex Calculation class.
* @package ceon_advanced_shipper
* @author Waqas Hussain <waqas20######################>
* @author Conor Kerr <[email protected]>
* @copyright Copyright 2010-2012 Waqas Hussain
* @copyright Copyright 2007-2012 Ceon
* @copyright Portions Copyright 2003-2006 Zen Cart Development Team
* @link http://dev.ceon.net/web/zen-cart/advanced-shipper
* @license http://www.gnu.org/copyleft/gpl.html GNU Public License V2.0
* @version $Id: class.AdvancedShipperFedExCalculator.php 981 2012-03-27 16:28:46Z conor $
// {{{ AdvancedShipperFedExCalculator
* Connects to FedEx online calculator and gets quotes for the shipping methods enabled in the
* configuration.
class AdvancedShipperFedExCalculator
// {{{ properties
* The configuration settings for this instance.
* @var array
* @access public
var $_config = null;
// {{{ Class Constructor
* Create a new instance of the AdvancedShipperFedExCalculator class
* @param array $fedex_config An associative array with the configuration settings for
* this instance.
function AdvancedShipperFedExCalculator($fedex_config)
$this->_config = $fedex_config;
// {{{ quote()
* Contacts Fedex and gets a quote for the specified weight and configuration settings.
* @access public
* @param float $weight The weight of the package to be shipped.
* @param float $price The total price of the items in package to be shipped.
* @param array $min_max Any minimum/maximum limits which should be applied to the final
* rate calculated.
* @return none
function quote($weight, $price, $min_max)
global $order;
if ($weight < 0.1) {
$weight = 0.1;
$rate_info = $this->_getQuote($weight, $min_max);
return $rate_info;
// {{{ _getQuote()
* Contacts FedEx, gets a quote, parses the response and builds the list of quotes.
* @access protected
* @return array|boolean Array of results or boolean false if no results.
function _getQuote($weight, $min_max)
global $db, $order, $currencies;
if (strtolower($this->_config['server']) == 'p') {
$fedex_url = 'https://gateway.fedex.com:443/xml';
$fedex_url = 'https://gatewaybeta.fedex.com:443/xml';
$fedex_key = $this->_config['fedex_key'];
$fedex_password = $this->_config['fedex_password'];
$fedex_account = $this->_config['fedex_account'];
$fedex_meter = $this->_config['fedex_meter'];
$shipper_country_sql = "
SELECT
countries_iso_code_2
FROM
" . TABLE_COUNTRIES . "
WHERE
countries_id = '" . (int) $this->_config['source_country'] . "';";
$shipper_country_result = $db->Execute($shipper_country_sql);
if (!$shipper_country_result->EOF) {
$shipper_country = strtoupper($shipper_country_result->fields['countries_iso_code_2']);
$shipper_postcode = $this->_config['source_postcode'];
$recipient_country = $order->delivery['country']['iso_code_2'];
$recipient_postcode = $order->delivery['postcode'];
$timestamp = gmdate('c');//'2010-08-06T21:48:17+06:00'
$saturday_delivery = ($this->_config['shipping_saturday'] != 0);
//BOF Residential Company Name Check
$residential = ($order->delivery['company'] != '' ? 'false' : 'true');
//EOF Residential Company Name Check
$drop_off_type = strtoupper($this->_config['drop_off_type']);
$packaging_type = strtoupper($this->_config['packaging_type']);
$get_account_rates = ($this->_config['rate_request_types'] == 1 ||
$this->_config['rate_request_types'] == 3 ? true: false);
$get_list_rates = ($this->_config['rate_request_types'] == 2 ||
$weight_units = strtoupper($this->_config['weight_units']);
$request = "
<RateRequest xmlns='http://fedex.com/ws/rate/v16'>
<WebAuthenticationDetail>
<UserCredential>
<Key>$fedex_key</Key>
<Password>$fedex_password</Password>
</UserCredential>
</WebAuthenticationDetail>
<ClientDetail>
<AccountNumber>$fedex_account</AccountNumber>
<MeterNumber>$fedex_meter</MeterNumber>
</ClientDetail>
<TransactionDetail>
<CustomerTransactionId>ACTIVESHIPPING</CustomerTransactionId>
</TransactionDetail>
<Version>
<ServiceId>crs</ServiceId>
<Major>16</Major>
<Intermediate>0</Intermediate>
<Minor>0</Minor>
</Version>
<ReturnTransitAndCommit>true</ReturnTransitAndCommit>
" . ($saturday_delivery ? '<VariableOptions>SATURDAY_DELIVERY</VariableOptions>' : '') . "
<RequestedShipment>
<ShipTimestamp>$timestamp</ShipTimestamp>
<DropoffType>$drop_off_type</DropoffType>
<PackagingType>$packaging_type</PackagingType>
<Shipper>
<Address>
<PostalCode>$shipper_postcode</PostalCode>
<CountryCode>$shipper_country</CountryCode>
</Address>
</Shipper>
<Recipient>
<Address>
<StreetLines>$recipient_street_address</StreetLines>
<City>$recipient_city</City>
<StateOrProvinceCode>$recipient_state</StateOrProvinceCode>
<PostalCode>$recipient_postcode</PostalCode>
<CountryCode>$recipient_country</CountryCode>
<Residential>".$residential."</Residential>
</Address>
</Recipient>
<ShippingChargesPayment>
<PaymentType>SENDER</PaymentType>
<Payor>
<AssociatedAccounts>
<AccountNumber></AccountNumber>
</AssociatedAccounts>
</Payor>
</ShippingChargesPayment>
" . ($get_account_rates ? '<RateRequestTypes>NONE</RateRequestTypes>' : '') . "
" . ($get_list_rates ? '<RateRequestTypes>LIST</RateRequestTypes>' : '') . "
<CustomerSelectedActualRateType>PAYOR_LIST_PACKAGE</CustomerSelectedActualRateType>
<PackageCount>1</PackageCount>
<RequestedPackageLineItems>
<SequenceNumber>1</SequenceNumber>
<GroupPackageCount>1</GroupPackageCount>
<Weight>
<Units>$weight_units</Units>
<Value>$weight</Value>
</Weight>
<Dimensions>
<Length>ceil($data->fields['products_freightquote_length'])</Length>
<Width>ceil($data->fields['products_freightquote_width'])</Width>
<Height>ceil($data->fields['products_freightquote_height'])</Height>
<Units>IN</Units>
</Dimensions>
</RequestedPackageLineItems>
</RequestedShipment>
</RateRequest>";
advshipper::debug("Data being sent to FedEx: <br />\n<br />\n" .
nl2br(htmlentities($request)) . "<br />\n<br />\n", true);
$body = $this->_post($fedex_url, $request);
if (!$body) {
advshipper::debug('Failed to connect to FedEx' . "\n\n");
return array('error' => 'Failed to connect to FedEx');
// Strip namespace prefixes
$body =
preg_replace(array('/<[a-zA-Z0-9]+:/', '/<\/[a-zA-Z0-9]+:/'), array('<', '</'), $body);
advshipper::debug("Data received from FedEx (with namespaces removed): <br />\n<br />\n" .
nl2br(htmlentities($body)) . "<br />\n<br />\n", true);
$xml = @simplexml_load_string($body);
if (!$xml) {
advshipper::debug('Unable to parse XML returned from FedEx' . "<br />\n<br />\n");
return array(
'error' => 'Invalid response from FedEx: '. $body
if (strtolower($xml->getName()) == 'fault') {
$error_code = $xml->detail->fault->errorCode;
$reason = $xml->detail->fault->reason;
return array(
'error' => 'FedEx: ' . $error_code . ': ' . $reason
$severity = $xml->HighestSeverity;
$message = $xml->Notifications->Message;
// Check for problem with postcode
if ($severity == 'ERROR' &&
strpos($message, 'Destination postal code missing or invalid') !== false) {
return array(
'error' => MODULE_ADVANCED_SHIPPER_ERROR_INVALID_POSTCODE
if ($severity != 'SUCCESS' && $severity != 'NOTE' && $severity != 'WARNING') {
advshipper::debug('Error occured when attempting to get response from FedEx. Severity' .
' was ' . $severity . "<br />\n<br />\n");
return array(
'error' => "FedEx: $message"
$rate_info = array();
foreach ($xml->RateReplyDetails as $child) {
$service_type = trim(strtolower((string) $child->ServiceType));
$service_name = constant('MODULE_ADVANCED_SHIPPER_TEXT_FEDEX_' .
str_replace('FEDEX_', '', strtoupper($service_type)));
if ($this->_config['shipping_service_' . $service_type] == 0) {
advshipper::debug('FedEx ' . $service_name . ' service not to be offered as it is' .
" not enabled in the FedEx configuration for the region.<br />\n<br />\n",
true);
continue;
if ($child->AppliedOptions == 'SATURDAY_DELIVERY') {
$service_name .= MODULE_ADVANCED_SHIPPER_TEXT_FEDEX_SATURDAY_DELIVERY;
$rate = (string) $child->RatedShipmentDetails->ShipmentRateDetail->TotalNetCharge->
Amount;
//If the method is configured to use list rates find the payor_list_package rate otherwise use account rates - RB
if ($get_list_rates == '1') {
foreach ($child->RatedShipmentDetails as $ratedetail) {
$ratetype = $ratedetail->ShipmentRateDetail->RateType;
if ($ratetype == 'PAYOR_LIST_PACKAGE') {
$rate = (string) $ratedetail->ShipmentRateDetail->TotalNetCharge->Amount;
//End of account rate change
// Rate is always returned in currency of account holder. Must convert to currency in
// use
$rate_currency = strtoupper((string) $child->RatedShipmentDetails->ShipmentRateDetail->
TotalNetCharge->Currency);
// Get the current currency in which the customer is viewing prices
$current_display_currency = strtoupper($_SESSION['currency']);
if ($rate_currency != $current_display_currency) {
// Must convert from FedEx currency to base currency
$rate_currency_conv_rate = $currencies->get_value($rate_currency);
if (is_null($rate_currency_conv_rate) || !is_numeric($rate_currency_conv_rate)) {
// FedEx currency doesn't have a conversion value, can't proceed!
return array(
'error' => sprintf(
MODULE_ADVANCED_SHIPPER_ERROR_FEDEX_CURRENCY_CONV_VALUE_MISSING,
$rate_currency)
} else if ($rate_currency_conv_rate <= 0) {
return array(
'error' => sprintf(
MODULE_ADVANCED_SHIPPER_ERROR_FEDEX_CURRENCY_CONV_VALUE_INVALID,
$rate_currency)
$rate_base_conv_rate = 1 / $currencies->get_value($rate_currency);
$rate = number_format($rate * $rate_base_conv_rate, 2, '.', '');
if ($min_max != false) {
// Apply the limit(s) to the rate
$rate_limited = advshipper::calcMinMaxValue($rate, $min_max['min'],
$min_max['max']);
if ($rate_limited != $rate) {
$rate = $rate_limited;
$rate_info[] = array(
'rate' => $rate,
'rate_components_info' => array(
array(
'value_band_total' => $rate,
'individual_value' => null,
'num_individual_values' => $weight,
'additional_charge' => null,
'calc_method' => ADVSHIPPER_CALC_METHOD_FEDEX
'rate_extra_title' => MODULE_ADVANCED_SHIPPER_TEXT_FEDEX_TITLE_PREFIX .
$service_name
if (count($rate_info) == 0) {
// No quotes
return false;
return $rate_info;
// {{{ _post()
* Do an HTTP POST call on a URL with given data.
* @access protected
* @param string $url The URL to send the request to.
* @param string $data The data to send in the request.
* @return string Data or false on error
function _post($url, $data)
$ch = curl_init($url) or die('Failed to load curl');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, TRUE);
//curl_set_opt($ch, CURLOPT_HEADER, FALSE);
curl_setopt($ch, CURLOPT_POST, TRUE);
curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, FALSE);
$data = curl_exec($ch);
curl_close($ch);
return $data;
Updated Post to show complete code
