If this is in the wrong area, I apologize.
I have tried 5 times, meaning I totally uninstalled ZenCart and started over and I still get the same error from easy populate.
Strange but there is no default language to work... That may not happen, just in case...
Warning Easy Populate Configuration Missing. Please install your configuration by clicking here
When I click the link (http://www.website.com/OUR_ADMIN/eas...langer=install It replies:
Warning EasyPopulate support & development by langer. Donations are always appreciated to support continuing development: [email protected]
Success Installation Successfull! A full download of your store has been done and is available in your uploads (tempEP) directory. You can use this as your 1st template for uploading/updating products.
Success File Full-EP2014Dec27-1705.csv successfully exported! The file is ready for download in your /tmp/ directory.
Warning An SQL error has occured. Please check your input data for tabs within fields and delete these. If this error continues, please forward your error log to the Easy Populate maintainer
When I try to do the SQL install I get:
Forbidden
You don't have permission to access /MyAdmin/sqlpatch.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Also easypopulate shows up in Tools, but not in configuration
Can anyone help?
