Results 1 to 5 of 5
    Jan 2011
    Adelaide, Australia
    Default Database problem - not all data is importing from DB copy
    I am currently doing my first version upgrade from 1.3.9h to 1.5.1 and am at the stage of importing database from existing working site into the test site - everything to do with products and product categories data is not loading into the test site database - address book, admin pages, and others have loaded but not the ones mentioned (as well as others).
    When importing the db I got an error message about duplicate addresses so I copied the original db minus address book - then after importing I got another error about address format so copied original db minus that as well and imported it however was still getting errors.
    I have tried copying just certain sections for importing to test db - the latest was I copied categories, category descriptions, products, product descriptions - received error message saying duplicate entry for categories (see below) - in checking that section the data was actually there as was category description however products and product description were not.
    Is there some reason for this occurring? are there permissions I need to adjust or something else? I figure after the last attempt mentioned that if I was to export then import only one data set at a time I will eventually get there but I have 4 other sites to upgrade so there is either something I am doing wrong or something I haven't done.
    cheers, Mike
    Error
    SQL query:
    -- Dumping data for table `categories`
    INSERT INTO `categories` ( `categories_id` , `categories_image` , `parent_id` , `sort_order` , `date_added` , `last_modified` , `categories_status` )
    VALUES ( 1, NULL , 0, 0, '2012-09-06 18:03:38', '2013-04-30 14:30:41', 1 ) , ( 2, NULL , 0, 1, '2012-09-06 18:04:08', '2014-07-30 17:33:38', 1 ) , ( 3, NULL , 0, 2, '2012-09-06 18:04:35', '2014-07-30 11:23:14', 1 ) , ( 4, NULL , 0, 3, '2012-09-06 18:05:05', '2013-04-30 14:31:42', 1 ) , ( 6, NULL , 0, 5, '2012-09-06 18:06:05', '2014-07-04 08:58:26', 1 ) , ( 7, NULL , 0, 6, '2012-09-06 18:06:26', NULL , 1 ) , ( 8, NULL , 0, 3, '2013-04-30 14:29:08', NULL , 1 ) , ( 9, NULL , 0, 9, '2013-04-30 15:24:09', '2013-04-30 15:24:27', 1 ) , ( 10, NULL , 0, 5, '2013-05-14 10:07:56', '2013-05-14 10:08:19', 1 ) , ( 11, NULL , 0, 3, '2013-06-28 10:02:15', '2014-07-13 09:25:56', 1 ) ;
    MySQL said: Documentation
    #1062 - Duplicate entry '1' for key 'PRIMARY' <<<<<<<<<<<<<< same message in every case
    Default Re: Database problem - not all data is importing from DB copy
    When you created the database export, I'm thinking that you didn't check the Add DROP TABLE / VIEW / PROCEDURE / FUNCTION / EVENT statement option under the Object creation options.
    Jan 2011
    Adelaide, Australia
    Spot on ...... Many thanks !!
    For future reference, this FAQ article mentions that: http://www.zen-cart.com/content.php?...atabase-backup
    Australia
    Quote Originally Posted by shags38 View Post
    You need to be very careful when importing the data 'in sections'. If you fail to import all of the related tables you can get some rather unpredictable and nasty behaviour.
    Unless you have a very good reason to do this it is much safer (and easier) to drop and re-import the entire database. That way you can be sure that everything maintains its relationships with everything else.
    Just sayin'
    RodG
  1. Importing Data from Old Zen Database
    By rka81 in forum General Questions
    Last Post: 19 Oct 2011, 07:57 AM
  2. Problem zencart does not copy all atributes
    By mrbert in forum General Questions
    Last Post: 9 Jun 2007, 02:12 AM
  3. Html editor language problem after importing database content from backup
    By stregoi in forum Templates, Stylesheets, Page Layout
    Last Post: 28 Apr 2007, 10:51 PM
  4. Not getting new data from database
    By StevenB in forum General Questions
    Last Post: 16 Apr 2007, 02:18 AM
  5. Help importing data into database...
    By dbunch in forum Currencies & Sales Taxes, VAT, GST, etc.
    Last Post: 18 Jan 2007, 11:45 AM
