    Jun 2008
    UK
    Default 1062 : Duplicate entry 'nnnnnn' for key 'PRIMARY' :: insert into sessions
    In my log I found this message ...
    [04-Mar-2015 17:00:41 Europe/London] PHP Fatal error: 1062uplicate entry 'nnnnnn' for key 'PRIMARY' :: insert into sessions
    And saw this post ...
    http://www.zen-cart.com/showthread.p...h-v1-5-4/page2
    I followed the post and did the coding changes ...
    And am now getting this message ...
    PHP Parse error: syntax error, unexpected 'delete' (T_STRING) in /home/tidytoys/public_html/includes/functions/sessions.php on line 69
    This is my current includes functions/sessions.php
    Can you please tell me what is wrong.
    line 58 - 92
       $val base64_encode($val);
        global
    $SESS_LIFE;
    $expiry time() + $SESS_LIFE;
    $sql "insert into " TABLE_SESSIONS " (sesskey, expiry, `value`)
                    values (:zkey, :zexpiry, :zvalue)
                    ON DUPLICATE KEY UPDATE `value`=:zvalue, expiry=:zexpiry"
    $sql $db->bindVars($sql':zkey'$key'string');
    $sql $db->bindVars($sql':zexpiry'$expiry'integer');
    $sql $db->bindVars($sql':zvalue'$val'string');
    $result $db->Execute($sql);
        return (!empty(
    $result) && !empty($result->resource));
      function
    _sess_destroy($key) {
        global
    $db;
    $sql "delete from " TABLE_SESSIONS " where sesskey = '" zen_db_input($key) . "'";
    $db->Execute($sql);
        return
    TRUE;
      function
    _sess_gc($maxlifetime) {
        global
    $db;
    $sql "delete from " TABLE_SESSIONS " where expiry < " time();
    $db->Execute($sql);
        return
    true;
    // Initialize session save-handler
    session_set_save_handler('_sess_open''_sess_close''_sess_read''_sess_write''_sess_destroy''_sess_gc');
    // write and close session at the end of scripts, and before objects are destroyed
    register_shutdown_function('session_write_close');
    Australia
    Default Re: 1062 : Duplicate entry 'nnnnnn' for key 'PRIMARY' :: insert into sessions
    Quote Originally Posted by toyseller View Post
    A "T_STRING" error is caused by an imbalance in the quote or apostrophe characters.
    The line number indicated is somewhat misleading in these cases, with the *actual* error being somewhere in a line of code that precedes the line indicated. The PHP Parser doesn't detect this imbalance until it reaches a part of the code that it determines to be syntaxually incorrect. In your case this is the line containing the 'delete'.
    line 58 - 92
        global
    $SESS_LIFE;
        return (!empty(
      function
        global
    $db;
    $db->Execute($sql);
        return
    TRUE;
      function
        global
    $db;
    $db->Execute($sql);
        return
    true;
    I'm not spotting anything amiss in the code as posted (other than an unbalanced '}' and that is because the code you have given starts partway within the _sess_read($key) function.
    The session.php code is pretty small, so it will probably be worthwhile to provide a copy of the entire file as that will give us a better chance to see exactly where the error is.
    RodG
    Jun 2008
    UK
    Thank you RodG :-D
    I only changed that portion of code.
    Line 69 is this line ... $result = $db->Execute($sql);
     * functions/sessions.php
     * Session functions
     * @package functions
     * @copyright Copyright 2003-2014 Zen Cart Development Team
     * @copyright Portions Copyright 2003 osCommerce
     * @license http://www.zen-cart.com/license/2_0.txt GNU Public License V2.0
     * @version GIT: $Id: Author: DrByte  Wed Mar 12 22:37:22 2014 -0400 Modified in v1.5.3 $
    if (!defined('IS_ADMIN_FLAG')) {
      die(
    'Illegal Access');
      if (
    IS_ADMIN_FLAG === true) {
        if (
    PADSS_ADMIN_SESSION_TIMEOUT_ENFORCED != && SESSION_TIMEOUT_ADMIN 900) {
    $SESS_LIFE 900;
        } else {
    $SESS_LIFE = (int)SESSION_TIMEOUT_ADMIN;
      } else {
        if (
    defined('SESSION_TIMEOUT_CATALOG') && (int)SESSION_TIMEOUT_CATALOG 120) {
    $SESS_LIFE = (int)SESSION_TIMEOUT_CATALOG;
        } else
        if (!
    $SESS_LIFE get_cfg_var('session.gc_maxlifetime')) {
    $SESS_LIFE 1440;
      function
    _sess_open($save_path$session_name) {
        return
    true;
      function
    _sess_close() {
        return
    true;
      function
    _sess_read($key) {
        global
    $db;
    $qid "select value
                from "
    TABLE_SESSIONS "
                where sesskey = '"
                and expiry > '"
    time() . "'";
    $value $db->Execute($qid);
        if (isset(
    $value->fields['value']) && $value->fields['value']) {
    $value->fields['value'] = base64_decode($value->fields['value']);
          return
    $value->fields['value'];
        return (
      function
    _sess_write($key$val) {
        global
    $db;
        if (!
    is_object($db)) return;
        global
    $SESS_LIFE;
        return (!empty(
      function
        global
    $db;
    $db->Execute($sql);
        return
    TRUE;
      function
        global
    $db;
    $db->Execute($sql);
        return
    true;
      function
    zen_session_start() {
    ini_set('session.gc_probability'1);
    ini_set('session.gc_divisor'2);
        if (
    ini_set('session.gc_maxlifetime', (SESSION_TIMEOUT_ADMIN 900 900 SESSION_TIMEOUT_ADMIN));
        } elseif (
    ini_set('session.gc_maxlifetime', (int)SESSION_TIMEOUT_CATALOG);
        if (
    preg_replace('/[a-zA-Z0-9,-]/'''session_id()) != '')
    zen_session_id(md5(uniqid(rand(), true)));
    $temp session_start();
        if (!isset(
    $_SESSION['securityToken'])) {
    $_SESSION['securityToken'] = md5(uniqid(rand(), true));
        return
    $temp;
      function
    zen_session_id($sessid '') {
        if (!empty(
    $sessid)) {
    $tempSessid $sessid;
          if (
    preg_replace('/[a-zA-Z0-9,-]/'''$tempSessid) != '')
    $sessid md5(uniqid(rand(), true));
          return
    session_id($sessid);
        } else {
          return
    session_id();
      function
    zen_session_name($name '') {
        if (!empty(
    $name)) {
    $tempName $name;
          if (
    preg_replace('/[a-zA-Z0-9,-]/'''$tempName) == '') return session_name($name);
          return
    FALSE;
        } else {
          return
    session_name();
      function
    zen_session_write_close() {
        return
    session_write_close();
      function
    zen_session_destroy() {
        return
    session_destroy();
      function
    zen_session_save_path($path '') {
        if (!empty(
    $path)) {
          return
    session_save_path($path);
        } else {
          return
    session_save_path();
      function
    zen_session_recreate() {
        global
    $http_domain$https_domain$current_domain;
          if (
    $http_domain == $https_domain) {
    $saveSession $_SESSION;
    $oldSessID session_id();
    session_regenerate_id();
    $newSessID session_id();
    session_id($oldSessID);
    session_id($newSessID);
    $_SESSION $saveSession;
          if (
    IS_ADMIN_FLAG !== true) {
    whos_online_session_recreate($oldSessID$newSessID);
    Australia
    Thank you RodG :-D
    Shoot. This is a worry. There are no syntax errors in this code.
    I don't know if it will provide any further clues or not, but I would suggest you try inserting a line that reads
    echo $sql ; die ;
    immediately before the line reading $result = $db->Execute($sql);
    I will warn you that the results won't be pretty (don't do this on a live site) and it will effectively 'kill' the store when this part of the code is reached. Anyway, if you do this and post a copy of the output you see it *might* provide a bit more insight as to the cause. (Although I'm really not confident about this).
    Theory dictates that you really shouldn't be getting the error that you are reporting and we are barking up the wrong tree.
    Another thing I would suggest would be to restore this file back to an original copy so as to confirm verify that the problem really is caused by the changes made to this file. In fact this is probably the 1st thing to try, especially if the site is live.
    Other than this, I'm all out of ideas at the moment.
    RodG
    How were the changes made to the file? (Ie. what editor was used?) (Trying to think of other reasons, as the code to the eyes looks right...)
    Could the error possibly be corrected by changing
     * Session functions
      die('Illegal Access');
      if (IS_ADMIN_FLAG === true) {
        if (PADSS_ADMIN_SESSION_TIMEOUT_ENFORCED != 0 && SESSION_TIMEOUT_ADMIN > 900) {
          $SESS_LIFE = 900;
        if (defined('SESSION_TIMEOUT_CATALOG') && (int)SESSION_TIMEOUT_CATALOG > 120) {
        } else
        if (!$SESS_LIFE = get_cfg_var('session.gc_maxlifetime')) {
          $SESS_LIFE = 1440;
     * Session functions
          $SESS_LIFE = 900;
          $SESS_LIFE = 1440;
  1. v151 Duplicate entry for key insert into sessions
    By RCwebdev in forum General Questions
    Last Post: 20 Aug 2013, 08:22 AM
  2. Replies: 2
    Last Post: 11 Dec 2012, 03:58 AM
