    Jun 2014
    hamilton, ohio
    Default Quantity Unit Errors when adding to list for products I DIDNT add to cart...
    Well I am at a loss. I am using the genesis template that i purchased from envato (which is a really nice template) but it has a bug for me where when I try to add a product from the list of products when viewing the category, I get quantity units errors for the products that I DON'T select to add to cart, which is weird. Nothing is showing up in my logs, so I am at a loss as to how to address this issue. I have contacted the author a week ago about a different issue, so I am not sure when I will be able to talk to them about it. It seems it is only with this template, and I am pretty committed to using it at the moment as I have customized it somewhat. These are the errors I get when I am directed to my cart for the items I did not select:
    Feb 2005
    Lansing, Michigan USA
    Default Re: Quantity Unit Errors when adding to list for products I DIDNT add to cart...
    You said it 'seems' to only happen with that template. Have you switched to the Classic template to be sure it's a template issue?
    Jun 2014
    hamilton, ohio
    I have tested on the my current template (avonlee contempo) and everything is hunky dory at the moment. I did just find a fix though from Ajeh on this thread: http://www.zen-cart.com/showthread.p...how-price-only
    ,where by selecting Display Product Add to Cart Button not to be shown in product listing, I get only an "add to cart button" instead of the quantity selection, which works great!
    Previously reported here: http://www.zen-cart.com/showthread.p...lder-attribute
    What I did to work around the issue was to create the file /includes/extra_cart_actions/fix_genesis_multiple_add_to_cart.php containing:
    // Correct the multiple-add-to-cart processing for the genesis theme.  There's an incompatibility between /includes/modules/genesis/product_listing.php's
    // use of the HTML5 "placeholder" attribute and the shopping-cart class.  The "placeholder", if not filled in, results in a blank value being returned on
    // the "multiple-add-to-cart" request which the shopping-cart interprets as an invalid value because it's not numeric.
    if (isset ($_GET['action']) && $_GET['action'] == 'multiple_products_add_product' && is_array ($_POST['products_id'])) {
      foreach ($_POST['products_id'] as $pid_check => &$quantity_check) {
        if ($quantity_check == '') {
          $quantity_check = 0;
      unset ($pid_check, $quantity_check);
      reset ($_POST['products_id']);
  1. v155 How to Add Custom Fields for Materials & Dimensions when adding products?
    By wmorris in forum All Other Contributions/Addons
    Last Post: 27 Jul 2016, 08:36 AM
  2. v151 pop up quantity when adding to cart
    By kitcorsa in forum General Questions
    Last Post: 24 Mar 2014, 02:50 AM
  3. v150 Quantity Unit errors
    By rjc_nnc in forum Basic Configuration
    Last Post: 2 Aug 2012, 03:15 PM
  4. Add to Cart Quantity alway shows 1 unit [TPP]
    By digulu in forum All Other Contributions/Addons
    Last Post: 24 Jan 2010, 04:38 AM
  5. Add JS Alert When Adding Products To Cart
    By DiZZ in forum General Questions
    Last Post: 15 May 2008, 06:06 PM
