    Default All products value total need help
    I have writen a short code that gives me an idea of how much goods i have in stock.
    here is the code i used with zen cart v1.5.1
          $all_products_sumquery_raw
    mysql_query("
    SELECT SUM(products_quantity * products_price_sorter) AS grand_total
    FROM products
    WHERE products_quantity > '0'
    $test1 mysql_fetch_array($all_products_sumquery_raw);
    echo
    '<h2>Total value: <span class="totalUred">'.number_format($test1[0], 2','' ').'</span>$.</h2>';
    Sinse i moved to 1.5.4 and coppied the code to admin/index.php the result is 0,00 (no value returned)
    Does somebody knows what change must be done?
    Best regards.
    My most recent work: magprom.net
    Dec 2009
    Amersfoort, The Netherlands
    Default Re: All products value total need help
    mysql_query is depricated.
    It is better to use the build in sql queries.
    like below.
    "SELECT SUM(products_quantity * products_price_sorter) AS grand_total
                                               FROM ' . TABLE_PRODUCTS . '
                                               WHERE products_quantity > '0'"
    $test1 $db->Execute($all_products_sumquery_raw);
    echo
    I tested your code but is returning an error.
    Just found that mysql_fetch_array is depricated too .
    Thank you for your help.
    I couldnt solve it by myself. I cant figure out where is the problem, no mater what i do i cant return any results even for the total products avaliable.
    Any help is appreciated.
    To use the $db things you need to have a:
    global $db;
    Try something like:
    global $db;
    $all_products_sumquery_raw = "SELECT SUM(products_quantity * products_price_sorter) AS grand_total
                                               WHERE products_quantity > '0'";
    $test1 = $db->Execute($all_products_sumquery_raw);
    echo '<h2>Total value: <span class="totalUred">'.number_format($test1[0], 2, ',', ' ').'</span>$.</h2>';
    global $db;
    Try something like:
    global $db;
                                               FROM " . TABLE_PRODUCTS . "
    Quotes are/were also incorrect around TABLE_PRODUCTS... See above.
    To possibly also see what is wrong as reported by ZC, check your logs directory for myDebug files.
  1. v151 Need help deleting all products!
    By discountvapor.net in forum Installing on a Linux/Unix Server
    Last Post: 25 Feb 2014, 04:46 AM
  2. Need Help with All Products Layout
    By Dagoon in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Oct 2009, 09:01 PM
  3. Need cart total value only. No currency sign.
    By strelitzia in forum Contribution-Writing Guidelines
    Last Post: 1 Oct 2008, 02:42 PM
  4. Total value of all listed items?
    By kpax in forum Templates, Stylesheets, Page Layout
    Last Post: 29 Aug 2007, 11:22 AM
  5. Adding products as a %age of total order with minimum value
    By gaekwad in forum Setting Up Categories, Products, Attributes
    Last Post: 9 Jul 2007, 10:06 AM
