Results 1 to 3 of 3
    Aug 2014
    Washington Township, Gloucester County, New Jersey, United States
    help question Need some help building a looping SQL query to fill an array.
    Building a custom mod that I plan on releasing later this month. Basically, I need to do the following 6 times. I know that repeating this code 6 times with different variables is wrong. I'm just not sure how to proceed. I apologize in advance for my noobness.
    $sql = "SELECT products_quantity
    FROM " . TABLE_PRODUCTS . "
    WHERE products_id='" . (int)$p_id_1 . "'";
    $p_stock = $db->Execute($sql);
    $item_1_stock = $p_stock->fields['products_quantity'];
    So let's say I start wtih this array :
    $_product_id_array = array ($p_id_1, $p_id_2, $p_id_3, $p_id_4, $p_id_5, $p_id_6);
    I need an array that would output these keys and values:
    item_stock_array(6) {
    ["product_id_1"]=>
    int($item_1_stock) // <-- Actual value from the query above, not the variable $item_1_stock
    ["product_id_2] => // and so on for all 6 values
    Default Re: Need some help building a looping SQL query to fill an array.
    Here you go:
    $result = $db->Execute ("SELECT products_id, products_quantity FROM " . TABLE_PRODUCTS . " WHERE products_id IN (" . implode (',', $_product_id_array) . ")");
    $item_stock_array = array ();
    while (!$result->EOF) {
      $item_stock_array[$result->fields['products_id']] = $result->fields['products_quantity'];
      $result->MoveNext ();
    Aug 2014
    Thank you! I had already figured out how to use the IN operator in my sql query and the implode function on my $product_id_array. I appreciate you filling in the rest. I actually understand it now :)
  1. Need help creating SQL query...
    By DigitalShadow in forum General Questions
    Last Post: 22 Jun 2011, 02:05 PM
  2. I'm making major progress in building my cart but I need some help with my layout
    By strugglingnovice in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Jul 2010, 10:44 AM
  3. Need help with SQL query. Want to make membership that expires.
    By TecBrat in forum Managing Customers and Orders
    Last Post: 18 Jun 2010, 03:43 PM
  4. Need help w/ SQL query in phpMyAdmin
    By audradh in forum General Questions
    Last Post: 16 Nov 2009, 01:05 PM
