    Aug 2014
    Lisbon
    Default Disabling column width and box width
    Is there a way to disable by configuration the width layouts for columns and boxes width ?
    Or just through the tpl files removing this
    <td id="navColumnOne" class="columnLeft" style="width: <?php echo COLUMN_WIDTH_LEFT; ?>">
    I guess this is safe to remove, but will it have any other impacts that I'm not seeing now ?
    “Though the problems of the world are increasingly complex, the solutions remain embarrassingly simple.” ― Bill Mollison
    Feb 2005
    Lansing, Michigan USA
    Default Re: Disabling column width and box width
    If I understand the question, check in Admin - Configuration - Layout Settings.
    Aug 2014
    Lisbon
    I was trying to understand if the layout columns and boxes width are really needed .
    In the admin layout config, one can only insert a value, even if it's left empty the style="width: ", it's always rendered.
    Probably, just creating a new configuration to be able to disable this, and make the changes in the tpl files.
    if it's enable
    <td id="navColumnOne" class="columnLeft" style="width: 150px ">
    if not
    <td id="navColumnOne" class="columnLeft" >
    something like that...
    Best Regards
    Aug 2014
    Lisbon
    I've managed to get around, (at least for now)
    I've created a new configuration in the layout config to enable or disable de layout columns with
    INSERT INTO `zen154`.`configuration` (`configuration_id`, `configuration_title`, `configuration_key`, `configuration_value`, `configuration_description`, `configuration_group_id`, `sort_order`, `last_modified`, `date_added`, `use_function`, `set_function`) VALUES (NULL, 'Disable Column / Boxes width', 'DISABLE_COLUMN_BOXES_WIDTH', '0', 'Disable columns and boxes with in the main tpl files', '19', NULL, NULL, '0001-01-01 00:00:00.000000', NULL, 'zen_cfg_select_option(array(''''1'''', ''''0'''')');
    Now in the tpl_main_page
    Something like this.....but there are 4 widths (left, right)...so probably this is not enough
    $column_width  = ((DISABLE_COLUMN_BOXES_WIDTH) == 0) ? 'style="width:'COLUMN_WIDTH .'"'  ''
    So now in the columns and boxes
    becomes
    <td id="navColumnOne" class="columnLeft" <?php echo $column_width; ?>>
    and the other related files that managed this style=widths for Boxes and left / right columns.
    I'm trying to make a template more html 5 style, that's why I'm trying to keep in the "zen way"
    I guess we could just delete this style: width.
  1. Fixed Center Box Width with Right Column Turned Off
    By uncharted in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Mar 2012, 11:35 AM
  2. center column width or centerbox width
    By nohart in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Apr 2010, 05:50 PM
  3. Column Width and Sidebox Width not working
    By khopek in forum Customization from the Admin
    Last Post: 8 Jan 2010, 06:22 PM
