I have a site that I monitor with Google Webmaster. I built the site like two years ago. A few weeks ago, the console began alerting me to an increase of 404 Not Found Errors. In the console, I drilled into the links to find the source. Google was claiming that many of the non-existing links were coming non-existing pages.
Further study showed that the links not being found did exist, before I switched over to ZC. And I was able to find some external websites that were linking in to my site, using the now ancient/non-working url's.
SOLUTION: I decided to build a redirect tree into the htaccess for the old sitemap.
But this seems to be creating even more problems!
This site, btw, uses Ceon URI and that is the only other content of the htaccess file. Here is that code:
## BEGIN CEON URI MAPPING REWRITE RULE
RewriteEngine On
RewriteCond %{REQUEST_URI} !\.[a-z]{2,5}$ [NC]
#   which are not covered by main file extension condition above
#   Uncomment the following line to apply this condition! (Remove the # at the start of the next line)
RewriteCond %{REQUEST_URI} !^/admin_S2g6 [NC]
RewriteCond %{REQUEST_URI} !^/editors/ [NC]
# Don't rewrite logs directory
RewriteCond %{REQUEST_URI} !^/logs/ [NC]
RewriteRule .* index.php [QSA,L]
There are two types of links in my legacy sitemap:
1) straight forward links and 2) links that contain regular expressions
I can get the straight links to give a 301 instead of a 404 by simply adding this below Ceon rewrite (currently 125 lines of this re-map):
Redirect 301 /Hakko_HJ5000_Heat_Gun_1300w_Dual_Temp_RC_Skin_B /index.php
Redirect 301 /prod-HAKKO_FX_8804_Hot_Tweezer-347.aspx /Hakko_950_Hot_Tweezer_Conversion_Kit_w_Holder
Redirect 301 /cat-Extraction_Kits-76.aspx /Fume_Dust_Extraction/Extraction_Systems
Redirect 301 /cat-Flux_and_Cleaners-27.aspx /Solder_Fluxes_Chemicals/Fluxes
Redirect 301 /cat-General_Purpose_Tweezers-51.aspx /General_Purpose_Tweezers_7
Redirect 301 /pdf/DesiccantRegeneration.pdf /download/ppk_pdf/DesiccantRegeneration.pdf
The problem is... I can't figure out how to get links in the second category to be treated literally. Here are some examples:
Redirect 301 /search.aspx?advanced=1 /index.php
Redirect 301 /pdf/48950%20Drawing.pdf /PROTEKTIVE_PAK_48950_BAG_PROTECTIVE-SHIELD_MBB_4_MIL_10INx20IN_100_EA_PACK
Redirect 301 /pdf/TDS_NC%20251%20Sn62%20&%20Sn63%20Solder%20Paste.pdf /index.php
Redirect 301 /detail.aspx?ID=124 /index.php
Redirect 301 /detail.aspx?ID=75 /index.php
Redirect 301 /detail.aspx?ID=80 /index.php
Can somebody please show me how to rewrite links like the ones above, such that the legacy link will be treated literally?
And yes, I know a blank space in a file name (%20) is bad form. But that is legacy, not my doing!
