I use servers free hosting but when I try to run, its going here http://www.hostinger.co.uk/error_403
Have not been to the page for a month but was working fine before. What do I need to show you to figure out what is going on?
This is my includes file
* @package Configuration Settings circa 1.5.1
* File Built by zc_install on 2014-02-28 02:38:09
/*************** NOTE: This file is similar, but DIFFERENT from the "store" version of configure.php. ***********/
* WE RECOMMEND THAT YOU USE SSL PROTECTION FOR YOUR ENTIRE ADMIN:
* To do that, make sure you use a "https:" URL for BOTH the HTTP_SERVER and HTTPS_SERVER entries:
define('HTTP_SERVER', 'http://thedreamweaver.bugs3.com');
define('HTTPS_SERVER', 'https://thedreamweaver.bugs3.com');
define('HTTP_CATALOG_SERVER', 'http://thedreamweaver.bugs3.com');
define('HTTPS_CATALOG_SERVER', 'https://thedreamweaver.bugs3.com');
// secure webserver for admin? Valid choices are 'true' or 'false' (including quotes).
// secure webserver for storefront? Valid choices are 'true' or 'false' (including quotes).
$t1 = parse_url(HTTP_SERVER);$p1 = $t1['path'];$t2 = parse_url(HTTPS_SERVER);$p2 = $t2['path'];
define('DIR_WS_ADMIN', preg_replace('#^' . str_replace('-', '\-', $p1) . '#', '', dirname($_SERVER['SCRIPT_NAME'])) . '/');
define('DIR_WS_CATALOG', '/Shop/zen-cart-v1.5.1-full-fileset-09182012/');
define('DIR_WS_HTTPS_ADMIN', preg_replace('#^' . str_replace('-', '\-', $p2) . '#', '', dirname($_SERVER['SCRIPT_NAME'])) . '/');
define('DIR_WS_HTTPS_CATALOG', '/Shop/zen-cart-v1.5.1-full-fileset-09182012/');
define('DIR_FS_ADMIN', realpath(dirname(__FILE__) . '/../') . '/');
define('DIR_FS_CATALOG', '/home/u401774422/public_html/Shop/zen-cart-v1.5.1-full-fileset-09182012/');
//the following path is a COMPLETE path to the /logs/ folder eg: /var/www/vhost/accountname/public_html/store/logs ... and no trailing slash
define('DIR_FS_LOGS', '/home/u401774422/public_html/Shop/zen-cart-v1.5.1-full-fileset-09182012/logs');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', '');
define('DB_CHARSET', 'utf8');
define('DB_SERVER', 'mysql.serversfree.com');
define('DB_SERVER_USERNAME', );
define('DB_SERVER_PASSWORD',);
define('DB_DATABASE', 'u401774422_dream');
define('DIR_FS_SQL_CACHE', '/home/u401774422/public_html/Shop/zen-cart-v1.5.1-full-fileset-09182012/cache');
// Main webserver: eg-http://www.your_domain.com -
// HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.your_domain.com
// HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.your_domain.com
// EOF
Using this as your server
I do not see this entry as being close to validCode:define('HTTP_SERVER', 'http://thedreamweaver.bugs3.com');
Code:define('DIR_FS_CATALOG', '/home/u401774422/public_html/Shop/zen-cart-v1.5.1-full-fileset-09182012/');
This is what it has always been. I heard that Zen Cart changed something a couples ago but I never got an email about, but my GF did but she does not have the email any more and that's about the time it quit working. Any idea what it was that was changed? Maybe that why it doesn't work any more.
It goes to the mail page outside of Zen Cart then when you click on the browse link (http://thedreamweaver.bugs3.com/Shop...2012/index.php) it never finishes. Here is the index.php:
* index.php represents the hub of the Zen Cart MVC system
* Overview of flow
* <ul>
* <li>Load application_top.php - see {@tutorial initsystem}</li>
* <li>Set main language directory based on $_SESSION['language']</li>
* <li>Load all *header_php.php files from includes/modules/pages/PAGE_NAME/</li>
* <li>Load html_header.php (this is a common template file)</li>
* <li>Load main_template_vars.php (this is a common template file)</li>
* <li>Load on_load scripts (page based and site wide)</li>
* <li>Load tpl_main_page.php (this is a common template file)</li>
* <li>Load application_bottom.php</li>
* </ul>
* @package general
* @version $Id: index.php 2942 2006-02-02 04:41:23Z drbyte $
* Load common library stuff
$language_page_directory = DIR_WS_LANGUAGES . $_SESSION['language'] . '/';
$directory_array = $template->get_template_part($code_page_directory, '/^header_php/');
foreach ($directory_array as $value) {
* We now load header code for a given page.
* Page code is stored in includes/modules/pages/PAGE_NAME/directory
* 'header_php.php' files in that directory are loaded now.
require($code_page_directory . '/' . $value);
* We now load the html_header.php file. This file contains code that would appear within the HTML <head></head> code
* it is overridable on a template and page basis.
* In that a custom template can define its own common/html_header.php file
require($template->get_template_dir('html_header.php',DIR_WS_TEMPLATE, $current_page_base,'common'). '/html_header.php');
* Define Template Variables picked up from includes/main_template_vars.php unless a file exists in the
* includes/pages/{page_name}/directory to overide. Allowing different pages to have different overall
* templates.
require($template->get_template_dir('main_template_vars.php',DIR_WS_TEMPLATE, $current_page_base,'common'). '/main_template_vars.php');
* Read the "on_load" scripts for the individual page, and from the site-wide template settings
* NOTE: on_load_*.js files must contain just the raw code to be inserted in the <body> tag in the on_load="" parameter.
* Looking in "/includes/modules/pages" for files named "on_load_*.js"
$directory_array = $template->get_template_part(DIR_WS_MODULES . 'pages/' . $current_page_base, '/^on_load_/', '.js');
$onload_file = DIR_WS_MODULES . 'pages/' . $current_page_base . '/' . $value;
$read_contents='';
$lines = @file($onload_file);
foreach($lines as $line) {
$read_contents .= $line;
$za_onload_array[] = $read_contents;
* now read "includes/templates/TEMPLATE/jscript/on_load/on_load_*.js", which would be site-wide settings
$directory_array=array();
$tpl_dir=$template->get_template_dir('.js', DIR_WS_TEMPLATE, 'jscript/on_load', 'jscript/on_load_');
$directory_array = $template->get_template_part($tpl_dir ,'/^on_load_/', '.js');
$onload_file = $tpl_dir . '/' . $value;
$read_contents='';
// set $zc_first_field for backwards compatibility with previous version usage of this var
if (isset($zc_first_field) && $zc_first_field !='') $za_onload_array[] = $zc_first_field;
$zv_onload = "";
if (isset($za_onload_array) && count($za_onload_array)>0) $zv_onload=implode(';',$za_onload_array);
//ensure we have just one ';' between each, and at the end
$zv_onload = str_replace(';;',';',$zv_onload.';');
// ensure that a blank list is truly blank and thus ignored.
if (trim($zv_onload) == ';') $zv_onload='';
* Define the template that will govern the overall page layout, can be done on a page by page basis
* or using a default template. The default template installed will be a standard 3 column layout. This
* template also loads the page body code based on the variable $body_code.
require($template->get_template_dir('tpl_main_page.php',DIR_WS_TEMPLATE, $current_page_base,'common'). '/tpl_main_page.php');
</html>
* Load general code run before page closes
<?php require(DIR_WS_INCLUDES . 'application_bottom.php'); ?>
if it was working, and then it stopped; something most likely happened at your host. if ZC changed and you did nothing, it would not affect you as you would not have updated to the new codeset.
i would explore the problem with your hosting company.
Even if ZenCart had changed something it would not affect what you have installedThis is what it has always been. I heard that Zen Cart changed something a couples ago but I never got an email about
Guess you get what you pay for
When this link finishes
This is presented
Again, You get what you pay forCode:Service Temporarily Unavailable The server closed the connection without sending any data. The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Due to heavy load on the server, connections may be temporarily blocked from locations that fetch an unusually high number of pages. We apologize for the inconvenience.
Come on, the other site I have on there works fine, but it does not use Zen Cart because that site does not sell anything. Also I cant get in the admin site either I just found out to manage the content of the page.
Trying to run site off line and come to find out that none of the PHP files will run.
